Go Back   HeliFreak > R/C Simulators Support > HELI-X Flight Sim
HELI-X Flight Sim HELI-X Flight Sim for Mac, Windows, Linux
Like Tree1Likes
  • 1 Post By MichaelS
Old 12-20-2020, 02:29 PM   #1 (permalink)
Default HELI-X V9.1 with VBarControl Touch
Version 9.1 is out:
You can use the VBarControl Touch via WLAN as controller for HELI-X:
https://www.heli-x.info/cms/blog/202...ch-and-heli-x/
Have fun.
richardv likes this.
MichaelS is offline        Reply With Quote Quick reply to this message
Old 12-20-2020, 03:45 PM   #2 (permalink)
Absolutely brilliant, I love it.
It uses the Touch's gimble calibration and switch assignments. No configuration required. Amazing work.
Specter 700 ~ VBar Control Touch ~ MKMHC / LARCS
VBar Utilities for VBCt
richardv is offline        Reply With Quote Quick reply to this message
Old 12-21-2020, 06:37 AM   #3 (permalink)
Kudos to Mikado and Heli-X for their collaborative effort to make this happen. It works flawlessly.
I have not seen complete step-by-step instructions, so here it goes:
1) Update VBC Touch radio (Transmitter Setup >> App Updater). Let the automatic "Checking File Integrity" process complete, and then press "Start Update". Let Update finish.
2) Install and activate the "Sim via Wifi" app. (Transmitter Setup >> Shop >> System)
3) Update Heli-X to version 9.1+, and restart Heli-X
4) Activate VBC Touch (IP) on Heli-X. (Configuration >> Global Settings >> Input System >> check the box). Then you have to restart Heli-X
5) Activate "Send UDP Control" on VBC Touch (Techtalk >> IP UDP Simulator >> check "Send UPD Control" box). This last step has to be performed every time you want to connect the VBC Touch wirelessly to Heli-X via Wifi, unless you also check the "Startup/Start at Switch On" box.
6) To end the wireless connection session, press "End Session" on the VBC Touch radio
Protos 700X Evo, Kraken/700 Havok/Kraken 580/Buddy 380 KSE, Logo 550SX V2; YGE "T" ESCs, Neo VLinks;VBC Touch, AGM Deep Cycle Batteries
Simulators (on MacBook Pro): Heli-X, neXt, AccuRC, RF9, Phoenix, AeroFly RC7 Ultimate
Citizen 259
curmudgeon is online now        Reply With Quote Quick reply to this message
Old 12-21-2020, 06:48 AM   #4 (permalink)
What do the "Startup/Start at Switch On" and "Reactivate/after other WiFi Activities" functions do?
*************EDIT********************
Answer from Mikado:
If you select Startup at Switch On, the feature will be automatically enabled when you switch on your radio, else you have to enable it manually if you want to sim.
Other internet traffic (e.g. Cloud access in the background) will suspend UDP control, so it does not interfere.
If you enable here, UDP control will be enabled again automatically thereafter.
Name:	Tx Sim WiFi Activation copy.png
Citizen 259
Old 12-21-2020, 07:49 AM   #5 (permalink)
I've enabled all of them and it works really well. Turn the radio on and start the sim, and it connects straight away.
One thing I've noticed, if I take a screenshot on the Touch, it disconnects from the sim, uploads the file to VStabi, and then reconnects. Not really an issue, as there's not much to screenshot, just an observation.
Old 12-21-2020, 07:58 AM   #6 (permalink)
I too noticed the screen shot disconnection issue. It seems to resolve by checking the 3rd box (Reactivate/after other WiFi Activities).
Citizen 259
Old 12-24-2020, 01:27 PM   #7 (permalink)
Default Intermittant connection
I keep having intermittent connection. I have un installed the wifi sim control on the vtouch and removed and reinstalled heli-x 9 on the pc. still intermittent connection.
any tips would be appreciated.
Sam
slairson is offline        Reply With Quote Quick reply to this message
Old 12-24-2020, 02:28 PM   #8 (permalink)
Originally Posted by slairson View Post
I keep having intermittent connection...
Even after checking the "Reactivate/after other WiFi activities" box?
Citizen 259
Old 12-25-2020, 06:08 AM   #9 (permalink)
Default Solved
I figured out the solution. I needed to go to transmitter settings;
Uncheck the cloud service,
Uncheck the online service.
Now I can sim without interruptions.
Merry Christmas and Happy New Year
Old 03-03-2021, 05:36 AM   #10 (permalink)
Dumb question -- Is via WIFI the only way, or can you use a USB cable as well with Heli-X?
Just returning to the hobby after 10+ year break. Considering a VbarControl Touch, but would hate if I can't use it with Heli-X
Dopey is offline        Reply With Quote Quick reply to this message
Old 03-03-2021, 11:11 AM   #11 (permalink)
The WiFi connection with the VBCT radio is just the latest feature. Any standard USB transmitter (Real Flight InterLink controller, Spektrum DX InterLink controller, eBay/Bangood USB controllers, etc), direct USB connection to a few transmitters (VBar Control, Jeti, etc), or standard USB adapters for just about any radio should work as well.
Citizen 259
Old 03-03-2021, 05:03 PM   #12 (permalink)
With the VBC and VBCt you can use directly a USB connection with HELI-X, similar to e.g. the Jeti transmitters. For "older" ones, you need an suitable USB interface,
Tags
heli-x, simulator
