Old 12-26-2020, 12:25 PM   #1 (permalink)
Default OS Max-55HZ Hyper Qustion
I have an OS 55HZ Hyper that I need to rebuild due to a badly stuck ring. but that not my question. I also have a new pump/regulator that I picked up in a trade.
Is there a difference between the the pumped and the non-pump carb or is there anything special I need to do to make the pump work with tis motor?
3drcbuilder is offline        Reply With Quote Quick reply to this message
Old 12-28-2020, 02:00 AM   #2 (permalink)
There is no OS "pump" for the 50-size motors.
Maybe you could post some pictures.
This is what the 55HZ-R DRS looks like:
https://www.os-engines.co.jp/english/101126e/
The 55HZ-R DRS uses a nipple on the backplate of the motor to attach a short piece of tube to a 1-way check-valve. The output of the 1-way check-valve pressurizes the fuel tank to around 7psi.
There is a regulator that is attached to the side of the carb's highspeed needle and that keeps a constant pressure through the needle to give a constant tune throughout the flight.
The OS 55HZ-R uses the 41L-R carb and the 55HZ-Hyper uses the 41L
My guess would be the regulator, the backplate and the parts to adapt to the carb would be about the only differences.
https://www.os-engines.co.jp/english.../pdf/15650.pdf
"Those who can make you believe absurdities can make you commit atrocities." (Voltaire)
Watch out: There are a lot of absurdities being thrown around lately.
+ > RIP: John Lewis
ticedoff8 is online now        Reply With Quote Quick reply to this message
