Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Like Tree5Likes
Old 12-27-2020, 07:16 PM   #1 (permalink)
Default hobbywing 130 will not calibrate
6 cell pack, ar7210bx. transmitter[dx9] setting within the range of 1940 to 1100. the esc works and starts the motor at about 40% of the stick, but i cannot get the 2 beeps at high throttle, it gives me 2 and quickly 1 more and no beeps at low throttle. is it possible i need a fully charged pack for this calibration.or am i missing something else.
rcflier1 is offline        Reply With Quote Quick reply to this message
Old 12-27-2020, 08:11 PM   #2 (permalink)
It's not beeping because the range is already set. If you want to reset it, follow this procedure:
After setting factory defaults on the ESC, power off the ESC.
Power on and Select “airplane” mode on the ESC, power off the ESC.
Set radio to Normal 0-100% throttle output and verify using your output monitor on the radio... set high stick at 100%.
Power on the ESC wait for the two beeps and move the throttle to low stick 0% throttle and wait for the arming tone.
You should always power off after setting defaults and before doing a throttle range calibration... default setting uses Heli GOV ELF mode. So setting Airplane mode after power cycle will reset the throttle range stored by the HW ESC.
Very important you have a linear throttle curve set-up. It must be from 0 to 100 percent.
NOTE: What mode are you running in the ESC?
Miracle Boy likes this.
Yellow 700X Dominator; Jeti DS-14; IKON2 FBL
Green 700X Dominator; Jeti DS-14; Spirit GTR FBL
Oxy4 Max; Jeti DS-14; IKON FBL
Tnjet is offline        Reply With Quote Quick reply to this message
Old 12-27-2020, 08:46 PM   #3 (permalink)
right now, default, store heli
Old 12-28-2020, 09:03 AM   #4 (permalink)
The ESC is already working normally because the default mode is Elf gov and and anything below 40% throttle is considered zero throttle/off in either gov mode per the HW manual
Its likely the well know BX calibration issue that occurs as the FBL unit and the ESC have contradicting features built into them. The BX wont pass any throttle through unless it sees zero first on power up, yet you have to power up the ESC at full throttle so its a standoff and the calibration wont initiate.
There are lots of methods on how to work around this. Here are a couple examples that should get you taken care of:
https://www.helifreak.com/showthread.php?t=745853
Tony
Synergy 516, Gaui R-5 Speed, Cypher Vtol Jet, Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
Old 12-28-2020, 11:22 AM   #5 (permalink)
that worked, i think. but no matter what i do it does not give me cell count in beeps, esc is set to auto detect. i don't think it's anything to worry about and i may just set it to 6 cells and be done with it
Old 12-28-2020, 12:37 PM   #6 (permalink)
Do you have the motor wires connected yet since its the motor that makes the beeps? The auto cell detect also assumes the number of cells based on voltage and can be thrown off if the packs voltage is different than expected
Tony
Old 12-28-2020, 01:30 PM   #7 (permalink)
yes, motor is connected.and seams to run fine, i also tried charging to 4 volts per cell.will not give me the 6 beeps
Old 01-09-2021, 12:12 PM   #8 (permalink)
The 130A will not give 6 beeps. It gives long tones and short tones. The long tones indicates 5 cells, the short only 1 cell. So for instance if you were using for 12S, it would give 2 long, 2 short. If you are using 6, it is one long, one short. The manual hasn't been updated, but if you look at one for the 200A, it's the same - as far as what beeps you should get for cell count.
PaoloFCantoni likes this.
-Ben
Old 01-15-2021, 06:19 PM   #9 (permalink)
thanks for that update, now i have another issue, the output on the side that has the fan/ or program box has gone dead. esc works but not the side port. waiting to hear from support, they sure take their time.truthfully, ready to take this out and put a castle in.this is my 1st hobbywing, and may be my last
Old 01-15-2021, 07:16 PM   #10 (permalink)
If the ESC works, what are you trying to do change programming?
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 01-16-2021, 08:34 AM   #11 (permalink)
Fan won't work either? Make sure you have connector positioned correctly.
-Ben
Old 01-16-2021, 09:19 AM   #12 (permalink)
i do have them plugged in correctly. i wanted to read the results from the 1st flight. outlet is dead
Old 01-16-2021, 10:14 AM   #13 (permalink)
the info from that port is unreliable and not accurate.. logs from the fbl, if capable, are better.
the throttle starting at 40% is correct and nothing wrong there. dont use a linear throttle for taking off. flick out of hold with a flat throttle curve at half stick and it will spool up nice if setup correctly.
Old 01-16-2021, 10:36 AM   #14 (permalink)
Does the program box communicate properly?
Have you updated the firmware recently? There have been newer versions released in the last couple months
NanoS2 - mCPX BL2 - 230s - 470LT - Goblin BT700 - LaTrax Alias
motoxxxman is offline        Reply With Quote Quick reply to this message
Old 01-16-2021, 10:51 AM   #15 (permalink)
As Tony said, the data from that port is complete garbage so you are not missing anything. It might as well not exist in the first place
Tony
Old 01-16-2021, 02:51 PM   #16 (permalink)
all well and good, and as a retired electronic tech, i do know electronics. with the port dead, there is no power to the fan either! new unit, i should not have these issues, and still no answer from hobbywing tech support.just say in
Old 01-16-2021, 03:33 PM   #17 (permalink)
your not gonna hear from hobbywing, dont hold your breath.
Old 05-05-2021, 11:46 PM   #18 (permalink)
I followed this while experiencing a similar issue with my 130A Opto V4. Got the expected beeps starting the calibration at full throttle but got only steady fast beeps after reaching low throttle. In both Gov Store and Fixed Wing mode.
Setting the throttle range to the maximum high and low permitted by the transmitter didn't fix it either.
I'm really at a loss here.
Logo 600 (VBar Neo), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), OMP M2 Explore, two 180CFX (one uSpirit), 130X, XK110, Nano CPX
PassinThru is offline        Reply With Quote Quick reply to this message
Old 05-06-2021, 07:10 AM   #19 (permalink)
do you have any means to check the actual throttle signal values going to the ESC?
Alternatively, do you have a servo tester you could use to do the throttle range calibration?
hamburger is offline        Reply With Quote Quick reply to this message
Old 05-06-2021, 07:16 AM   #20 (permalink)
what tx?
