Old 02-13-2017, 10:43 PM   #1 (permalink)
Default Setup for other Heli ? 500 or 600 for a 550 ?
I am fairly new to the VControl. I am going to setup my Diabolo 550 (550mm blades). Do I start with the 500 heli setup program ?
Diabolo 700 BE, 600, Synergy-696, E5SS, Logo 600, 200, Goblin Raw 700, VCT, VBar, Egodrift, Scorpion, Kontronik, MKS, XPert, KST
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 02-14-2017, 06:18 AM   #2 (permalink)
I setup my Goblin 570 under Other 600..
OptiFuel TEAM PILOT
busterboy is offline        Reply With Quote Quick reply to this message
Old 02-14-2017, 07:17 AM   #3 (permalink)
Thank you. That's what I am not sure about for a 550 do you use 500 or 600 ?
Old 02-14-2017, 10:07 AM   #4 (permalink)
Never set up a 550 on vcontrol. But, I've flown plenty. My feeling is they are closer to a 600 feel than a 500 feel. So I'd start with 600 setup if it were mine to do. I redid my 600se once from the 600 preset by accident and honestly couldn't tell the difference in the air. I think once you go through the tweak guide you'll dial it in perfectly either way.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
cudaboy_71 is offline        Reply With Quote Quick reply to this message
Old 02-14-2017, 02:23 PM   #5 (permalink)
I think if it was me I would compare the data then make the call. Here is some basics for align helis.
500 935mm
Main blade 470mm
Tail blade 78mm
Weight 1450g
550 1163mm
main blade 550
tail blade 90mm
weight 2590
600 1160mm
main blade 600mm
tail blade 95mm
weight 2900
http://www.aligntrexstore.com/T-REX-...7X_p_4773.html
http://www.aligntrexstore.com/T-REX-...X-_p_4587.html
http://www.aligntrexstore.com/-T-REX...4A_p_4365.html
Shawn550 is offline        Reply With Quote Quick reply to this message
Old 02-14-2017, 02:37 PM   #6 (permalink)
I setup my Diabolo 550 using the 500 on the VBC. I only needed to adjust the tail gain on the maiden, the rest was spot on
Henseleit TDR2 - TDF - TDSF - Glogo - L690sx - Strike 7 - Agile 7.2 Gasser - KDS A7
3DME Alloy Vtouch Design Team
www.inverteddownunder.podbean.com
Ozzy Mozzy is offline        Reply With Quote Quick reply to this message
Old 02-14-2017, 03:35 PM   #7 (permalink)
Not sure of your setup...
Diablo 550 1060mm
Blades 550mm
Tail 80mm
Weight 2100 grams
http://minicopter.de/en/diabolo550
Old 02-16-2017, 08:10 PM   #8 (permalink)
I asked the same question on Vstabi.info and the answer was to start with the 500 setup. And change the heli size value a few points "in between" ;-)
Old 02-17-2017, 12:41 AM   #9 (permalink)
Good to know this.
- Michalis |OXY Heli|XNova Motors|
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 02-17-2017, 07:38 AM   #10 (permalink)
I think that may make sense as the diabblo tail blades are 80mm and the align 500 tail blades are 78mm.
Old 02-17-2017, 07:42 AM   #11 (permalink)
You can use 85mm as well, which i will install on my setup.
Old 02-27-2021, 01:45 PM   #12 (permalink)
Heli size value in between???
DIABOLO 550, DIABOLO 800 (ORDERED)
SAB: KRAKEN
VCONTROL*NEO*TRIBUNUS*MKS*TORQ*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is online now        Reply With Quote Quick reply to this message
Old 02-27-2021, 07:44 PM   #13 (permalink)
Heli size selection is not that critical to get it exactly as it merely is a function to let the control loops have a starting point for mass distribution. Normally use the size value closest to your helicopter size and all will work perfectly.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
