Old 01-08-2021, 04:32 AM   #1 (permalink)
Default S-Bus wiring advatages
Hi all
I never had a Futaba S-Bus system in the past. Wiring was always challenging using other conventional rc systems. Has anybody used the S-Bus wiring system in his heli? If so are there any real advantages? Are there any S Bus wiring pics available?
Many thanks in advance.
Kind regards
Yaya
YAYA is offline        Reply With Quote Quick reply to this message
Old 01-08-2021, 04:56 AM   #2 (permalink)
On pretty much all fbl controllers it takes a single wire from the sbus receiver to the fbl controller to carry all of the channels.
What I did using vbar (not NEO) is using an ESC with two outputs is run the main to the vbar ESC in and the secondary power to the receiver.
If the ESC you have only has a single output that will go to the ESC input/output on the fbl controller you are using. The receiver will get its power from the sbus socket on the fbl controller.
Don't quote me to answer please, just add a comment.
Andy from Sandy is online now        Reply With Quote Quick reply to this message
Old 01-08-2021, 05:25 AM   #3 (permalink)
Hi Andy
Thanks.
I had the idea to have only one wire from the fbl to the first servo and then from first servo to second servo etc. But this would probaby only possibe if the fbl supports s-bus in this sense.
KR
Yaya
Old 01-08-2021, 05:52 AM   #4 (permalink)
On most models with 3 servos round the mast and the relative close proximity of the other controls it probably isn't necessary.
Futaba have a nice video showing a plane with 2 servos per control surface using s.bus hubs to connect everything up. That definitely reduces the amount of wiring considerably.
Old 01-08-2021, 06:06 AM   #5 (permalink)
i liked this video for easily showing the installation & programming of SBus setups: https://www.rcgroups.com/forums/show...Video-Tutorial
so it's more a squid (or multi-squid) than a ('daisy chain') bus installation... and the question if it would be a real advantage in a trainer heli should be answered easily plus the question on 'all that juice' for a 700 swash through 1 cable/connector too... (of course very different in a more complex/bigger/multiservo/scale model & cabling w/ powerboxes etc where it can show all of its power and flexibility)
... so i am connecting every single servo to my ciu-3 to program the servo parameters and forget about the rest
Ciao
Michael
minicopters & Logos, YGE, Egodrift, Spirit 2/RS/GT/GTR, Jeti DS-12/Spirit Ed.
Rabid121 is online now        Reply With Quote Quick reply to this message
Old 01-12-2021, 07:19 AM   #6 (permalink)
The only thing I'd add to the above is that Main/Slave going to FBL/Rx depends on what you want to run as governor. I run Kontronik powerjives and a Kolibri and their govs are very very good. I can't say that they're better than CGY750/760R governor, but I prefer the simplicity of having SBUS handle all the channels for servos and gains, and simply plugging the ESC master into Ch3 PWM on the R7003SB Rx.
To answer the OP's question, SBUS is good for reducing cabling on models, but on an FBL heli, the amount isn't really all that much. It shines in large aircraft with many servos. Actually technically speaking, you have more wires with SBUS hubs than using traditional PWM, but the beauty is that you do not need to extend every single servo to reach say from the rudder/elevator servos all the way to the Rx. Instead you just have a network of SBUS hubs with each servo hooking into that 'spine'.
Harry
Thunder Tiger Raptor E720 CGY750 | Mikado Logo 700 CGY760R |SAB Kraken 580 CGY760R| Powered by Futaba 18SZ
PlaneHazza is offline        Reply With Quote Quick reply to this message
