Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion > KDS Agile 7.2
KDS Agile 7.2 KDS Agile 7.2 Discussion
Old 12-09-2019, 01:41 AM   #1 (permalink)
Default 7.2 one way alternative
I had to replace the one way on my 7.2. So I thought that maybe the the new A7 one way would work.
The A7 has the OWB on the intermediate shaft. Seems like a better place. After a little fussing I was able to get it to work.
If anyone else is interested heís some pics.
Had to turn the shaft down to 10mm. Then remove the dust shields on the old OWB and pack it with JB weld.
Itís very smooth now and has been holding strong.
Brendan
goof2 is offline        Reply With Quote Quick reply to this message
Old 12-09-2019, 04:22 PM   #2 (permalink)
Brendan
Nice! Frankly, I don't know how anyone can keep a household running without a machine shop at home.
Mr_Dirt is offline        Reply With Quote Quick reply to this message
Old 02-13-2020, 08:34 PM   #3 (permalink)
Hey goof, how's that one way holding up? Finding it quite hard to source a one way for the 7.2, and wouldn't mind dusting off the ole atlas lathe..
Randoo is offline        Reply With Quote Quick reply to this message
Old 02-26-2020, 01:21 AM   #4 (permalink)
The A7 oneway is holding up good. I think the head feels smoother free wheeling also.
I couldnít source a decent 7.2 oneway that would hold up either. Thatís why I converted.
I pmíd you. Let me know how you make out.
Brendan
Old 04-15-2020, 08:40 AM   #5 (permalink)
Glad to see this is still working! I was hoping there would be a lot of parts compatibility between the 7.2 and A7.
#749: The end won't be for everyone. The choice, to know, will be yours
-Let's Go Brandon!!!
Skeezix is offline        Reply With Quote Quick reply to this message
Old 04-27-2020, 12:36 AM   #6 (permalink)
The one-way went out on my buddy's 7.2 today. I haven't quite checked to confirm that it isn't the bearing slipping in the hub. I think the actual bearing itself can be purchased from VXB.COM I need to take some measurements to see if they have it.
Otherwise, it looks like the bearing with the hub isn't in stock here in the US.
Chris Berardi
BobbyJack's Hobbies
Agilefalcon is offline        Reply With Quote Quick reply to this message
Old 04-27-2020, 07:51 AM   #7 (permalink)
Maybe Goof2 can whip up another modified A7 part and send to you? Itís an idea to keep you flying.
Old 05-02-2020, 01:01 PM   #8 (permalink)
I tried a few bearings they just wouldnít hold up. The one that KDS sells is about $50 and I couldnít source it in the US.
I think the real problem comes from the oneway assembly it self. After awhile and maybe a couple of crashes the crown gear hub no longer can float smoothly on the inside of OWB. This causes to much load in the vertical direction on the bearing. There just not meant for that kid of load.
Brendan
Old 05-25-2020, 01:52 AM   #9 (permalink)
How tight is the fitment? Wouldn't locktite #648 be a better solution than JB Weld considering that this is exactly the sort of application it's meant for (i.e. fixing slip fit components like pinions and pulleys onto shafts)? Also with enough heat the parts can be separated unlike epoxy which is effectively permanent.
Old 05-28-2020, 02:06 AM   #10 (permalink)
Default VXB.COM
Did we figure out the size of the one way?
VXB.COM
Austin, TX
HoudiniRCHeli Podcast
rspiegel is offline        Reply With Quote Quick reply to this message
Old 06-04-2020, 04:16 PM   #11 (permalink)
Atomic
No jb weld is to lock the old owb from working. Creating a solid spacer.
Rspiegel
Which bearing size you looking for old 7.2 or new A7?
Old 06-04-2020, 08:25 PM   #12 (permalink)
Default OneWay
Old 7.2 . I have a spare coming with my crashed kit. But figured i would get ahead of the game on it if i could.
A7 I have not seen any issues with the one way.
Austin, TX
Old 06-06-2020, 10:57 AM   #13 (permalink)
Old 06-07-2020, 02:18 AM   #14 (permalink)
Talking Not bd
Not bad 19$
https://www.amazon.com/Boca-Bearing-.../dp/B00DV1WT3Q
Now pressing it in and out may be a bit of a pain...
Austin, TX
Old 06-07-2020, 12:53 PM   #15 (permalink)
Heat up the housing. It will come right out.
Make sure the bearing you order has a key cut on the inside and outside.
You will also have to grind a flat for set screw.
Old 06-09-2020, 05:37 PM   #16 (permalink)
Default OK
OK not sure what that is but ok,
?You will also have to grind a flat for set screw.?
Austin, TX
Old 01-11-2021, 12:38 AM   #17 (permalink)
Never seen a one way like that used in a helicopter most either use a sprag clutch or a ramp roller clutch. the A7 one way uses two ramp roller clutches for example.
