Go Back   HeliFreak > R/C Electronics Support > Spektrum FBL System > Spektrum FC6250HX
Old 01-15-2021, 01:12 PM   #1 (permalink)
Default center pulse width
I thought I saw it the first time I set it up but cant find it now and cant find any mention of it anywhere. I have a 760/560 tail servo on now and want to drop a 1520/333 in. I did a factory reset but it still never popped up.
Deadpony is offline        Reply With Quote Quick reply to this message
Old 01-15-2021, 01:20 PM   #2 (permalink)
Setup->Tailrotor->Output Setup->Frame Rate and select the 333hz setting.
Horizon Hobby, LLC
My Projects: 150 S, 200 SRX, 200 S, 230 S v1/v2, 270 CFX, Fu270, Fu480: AR636/AR6335 Heli, FC6250HX, AR6250MHX
brianbremer is offline        Reply With Quote Quick reply to this message
Old 01-15-2021, 01:46 PM   #3 (permalink)
Thats not center pulse width. I need to change center from 760 to 1520 on the tail.
Old 01-15-2021, 01:51 PM   #4 (permalink)
The frequency determines the center pulse width.
Horizon Hobby, LLC
Old 01-15-2021, 01:57 PM   #5 (permalink)
I plugged the 1520/333 servo in after setting the frame rate to 333 and it was still at 760, only moved to one side with rudder input or, half travel.
Old 01-15-2021, 01:59 PM   #6 (permalink)
Edit... Possibly I misread the original comment.
"Well, nothing bad can happen now."
wjvail is online now        Reply With Quote Quick reply to this message
Old 01-15-2021, 02:05 PM   #7 (permalink)
deleted
Old 01-15-2021, 02:19 PM   #8 (permalink)
Guess I just had to turn the system off. All works now.
Old 01-15-2021, 02:27 PM   #9 (permalink)
Double check Setup->Tailrotor->Output Setup->Frame Rate and make sure the setting is still set to 333hz. Always exit forward programming and wait to see one green flash before powering down to ensure the settings are saved.
wjvail
Fact, not conviction
Horizon Hobby, LLC
Old 01-15-2021, 02:29 PM   #10 (permalink)
Ok so it works with my align 655 tail servo witch is 1520/333, what would it do to a bk 7005hv that is a 760/333 tail servo?
Old 01-15-2021, 02:58 PM   #11 (permalink)
Some info on the BK topic.
https://www.helifreak.com/showthread.php?t=859339
Horizon Hobby, LLC
Old 01-15-2021, 03:07 PM   #12 (permalink)
Perfect, Thank you very much.
Old 01-16-2021, 09:46 AM   #13 (permalink)
wjvail
My apologies. I read your comment to say that a servos frame rate was determined by its center pulse width and vice versa. Of course that isn't the case. For instance there are both 760/333 and 1520/333 servos.
I believe you were saying setting the FBL frequency is used to set the center pulse width for the controller's programming (which may or may not be the servo's actual value).
Again. My mistake.
