Go Back   HeliFreak > R/C Electronics Support > Spektrum FBL System > Spektrum FC6250HX
Old 02-01-2021, 10:40 AM   #1 (permalink)
Default Are there compatibility issues with Hobby Wing?
Hi all I have the Spektrum FC6250HX FBL, it was originally set up with the stock Align ESC, but I prefer the Hobby Wing Platinum series ESC’s because I like their governor.
I have tried a couple of different things suggested over on the Hobby Wing ESC forum, and posted also to see if anyone had used this combination and knew of the procedure to set end points.
There were only crickets chirping....
So I thought I’d try here and see if anyone is running a Hobby Wing Platinum V4 and might know something.
The issue is one the tones from the motor are weak (have to put my ear right up to the heli to hear them, and the motor comes on line at half throttle.
My curves are set at linear, and the throttle end points on the radio are 100/100 any ideas?
Blade: Nano QX, SR, 230s, 400 3D
Walkera: V120D02s
Align: 450L Dominator, 450 Pro DFC,
500 Pro DFC
nighttrain06 is offline        Reply With Quote Quick reply to this message
Old 02-01-2021, 10:58 AM   #2 (permalink)
The Hobbywing gov doesn’t start until the throttle is above 40%. If you’re using the HW governor you need to have flat throttle curves.
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2
Old 02-01-2021, 12:28 PM   #3 (permalink)
I am using the 120 V4 Hobbywing with the 6250 and all is well. When I set the end points, I used the same procedure people would use to set up the 7200 and 7210 Spektrum FBL units bypassing the internal bec for a separate power source. I'm not sure if that is really necessary with the 6250 but it can't hurt. If you are not familiar with what I am referring to, most if not all, Spektrum receivers will not let you initialize the FBL if the throttle is at full throttle so you have to use a work around. Search for end points 7200 or similar and you will find the info you need. There are a lot of references to it on Helifreak.
T-Rex 700X, Goblin Black Thunder 650 & 570 Drake, DX9, Microbeast, Neo, Axon, FC6250
Chasm is online now        Reply With Quote Quick reply to this message
Old 02-01-2021, 02:00 PM   #4 (permalink)
That’s the thing it does act like it is set for governor, but I have not even programmed it yet, throttle curves are linear.
I did set the Align ESC for governor, and programmed everything then. But somehow either in the FBL or whatever it seems to think it’s still in gov mode. Throttle curves were changed back to linear when I installed the Hobby Wing.
Walkera: V120D02s
500 Pro DFC
Old 02-01-2021, 02:08 PM   #5 (permalink)
I found that thread and that was what I tried. The motor though only made 3 audible beeps, when I initialized the ESC, then I realized the beeps were very faintly audible so I tried again and I could hear the beeps when I held my head very close to the heli, I heard the 6 beeps and then two beeps very faintly. But then when I powered it up after completing the setup the throttle has too go to half stick before it spoils, the motor upon initialization makes I think 2 or 3 loud beeps then as before I have to be very close to it to hear them.
Walkera: V120D02s
500 Pro DFC
Old 02-01-2021, 02:21 PM   #6 (permalink)
Is it possible that the Hobbywing was already set to the internal (ESC) governor?
Old 02-01-2021, 02:42 PM   #7 (permalink)
I was just thinking I should plug in the program box and see what settings are on it or set it any way then try to do the end points.
Something else though I was thinking was maybe I need to drop my end points on the throttle settings to 30 each and try to do like a guy did in a video where he would bring them up slowly until it initialized on both high and low points. I believe he was doing this on a Castle ESC though.
Walkera: V120D02s
500 Pro DFC
Old 02-02-2021, 01:18 PM   #8 (permalink)
Ok I finally figured out the issue.
The esc was set for ELF gov from the factory! There is a setting that you can use to go to linear throttle in the setup.
Once I changed that, powered it up and reinitialized it, i had my end points!
Still for some reason the tones at the start I think 2 or three are normal and the rest are barely audible. I am not sure what is up with this, but i would like to resolve that issue in order to know that the ESC and motor have come fully online!
So feel free to give any suggestions as to what the issue might be!
Thanks also for the help!
Walkera: V120D02s
500 Pro DFC
Old 02-02-2021, 03:26 PM   #9 (permalink)
You don’t need to set the ESC to linear throttle to set the endpoints if you’re planning to use the ESC governor. You will need to reset the endpoints when you switch back to ELF or Store governor anyway. In either governor mode, the Motor won’t start until you get over 40% throttle; that’s how the Hobbywings are. You should be using a flat throttle curve with any governor.
There are a lot of reasons why the tones from the motor are not as loud as expected or vary. It could be a bad phase caused by a broken wire, a short or bad solder joint. The motor just might not make a lot of noise. Or depending on the phasing where the motor is resting, can affect the sound.
Old 02-03-2021, 01:17 PM   #10 (permalink)
Yes I finally got everything as it should be working.
I had thought what the hell I was going to run the gov anyway. What concerned me were the tones and not being able to hear them. It turns out the end points were being set all along, I just didn’t hear the times they were so low.
Once I set my gov store and went through the program the tones worked like a champ! So it’s good!
Thanks for helping out.
Walkera: V120D02s
500 Pro DFC
