Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support |
#1 (permalink) |
![]() Hello guys,
Somebody know how can I eliminate the extreme vibration warning in the V-bar Control Touch? This warning appears during the flight. Tks, Felipe
Goblin 570 Sport Goblin 700 Black Thunder Sport Goblin 700 Kraken |
#2 (permalink) |
![]() Check vibrations with the analyzer at a hover.. I was told don’t worry about the in-flight ones because it’s picking up the movements as you’re flying.
a bunch of helis... now all vcontrol and neo..finally :lol |
#3 (permalink) |
![]() Join Date: May 2015
![]() Hello Tonys, thank you!
My english is terrible, sorry . I was referring to the radio warning (alarm). The radio vibrates and a warning appears on the screen, is there any configuration that removes this function?
#4 (permalink) |
![]() What is the warning?
If you go to the alarm setting it should have the option to set voice and vibration on and off.
Don't quote me to answer please, just add a comment. |
#5 (permalink) | |
![]() Quote:
It is an audible and visual (on the radio screen) notification. When the Vbar identifies an extreme vibration, the radio displays this notification "Extreme Vibration". If I turn off this function directly on the radio system in volume, all notifications will disappear, I would like only the "Extreme vibration" notification disappear. Sorry if I explained something wrong or that you can't understand.
#6 (permalink) |
![]() If you are getting a visual warning, you have a vibration problem that needs addressed I believe. Tony was referring to a couple showing up in the logs.
Vcontrol Touch, AccuRC Simulator Oxy 5 MEG, 4 MAX, 2 (215) SAB Goblin 500 Sport XL Power Specter 700 |
#7 (permalink) |
![]() I believe to be normal vibrations during the flight, I only wanted turn off this notification in my radio, is boring to have this notification during the flight, but I don't know if it is possible.
Goblin 570 Sport Goblin 700 Black Thunder Sport Goblin 700 Kraken Last edited by Lipe; 02-03-2021 at 08:25 AM.. |
#8 (permalink) |
![]() You better have a look at the event log. If you are getting 5+ extreme vibrations in a row, then I think you have a problem.
I don't know if you can turn the alerts off individually. I know you can turn temperature alerts off for your ESC in the ESC's app (YGE in my case) but that was also a bad idea as it was alerting me of an actual problem (wrong sized pinion gear for my setup).
#9 (permalink) | |
![]() Quote:
#10 (permalink) |
![]() that looks like the end of your flight where the extreme vibration level came when you landed. I often get one of those. Is that when your screen is lighting up and vibrating warning about vibration level? Mine doesn't do that, if so.
#11 (permalink) | |
![]() Quote:
Thank you very much for you help ![]()
#12 (permalink) |
![]() Hello,
The VBCT is good. I had the same alert, and I was disapointed.... Why???? On my goblin 700 thunder Sport, I change, parts after parts - tail shaft - main shaft - secondary shaft - and...... motor shaft..... Finally, may main motor shaft wasn't good.... Now, I replace all the old parts except motor shaft, and no alert after 15 flights.... Then, yes, the sensor is sensitive, but it gives good information .... good things for my heli....
GOBLIN 380 - 420 - 500 - 500 SPORT - 570 - THUNDER SPORT / LOGO 480 - 690 / OXY 3 - 4 VBAR CONTROL TOUCH - NEO - KONTRONIK AND YGE ADDICT |
#13 (permalink) |
![]() I’ll get them occasionally. Most of the time it’s at the end of an auto when I don’t set it down softly and it drops the last couple inches. If you’re not getting the warning all the time I wouldn’t worry about it.
#14 (permalink) |
![]() Mikado informed that this audible warning for "Extreme Vibration" does not exist, so it was I who was associating the warning on screen with the audible warning, but the audible warning referred to something else, the battery history function in the cloud was disabled and the alert stopped.
Reply email:
