Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree27Likes
Old 02-10-2021, 12:07 AM   #21 (permalink)
Originally Posted by Locktite View Post
One thing I needed to do when installing them into the kraken 700 head was use a deburring tool to chamfer the edge of the headblock so the dampener went in without damaging the inner o ring on the dampener.. also use lots of lubrication. ..the kraken 580 the chamfer was not needed
Like a reamer canopy opening tool or exactly what speaking to on the inner head block ?
OICU812 is online now        Reply With Quote Quick reply to this message
Old 02-10-2021, 01:03 PM   #22 (permalink)
No i suggest using a deburring tool like in the link I have provided.. you can maybe get away with a canopy reamer if its large enough. If you take a look at the picture of the headblock it’s the inner diameter of where the dampener goes in that you chamfer
Hand Deburring Tool Kit, Golden^Li Burr Cutter with NB1100 Anti-Slip Handle + 10 Pcs 360°Rotary HSS Deburr Blades, Burr Trimming Scrapers Kit for Aluminum, Copper,Steel,Wood and Plastic https://www.amazon.com/dp/B07SB5HB6T...ing=UTF8&psc=1
Spencerkey likes this.
Tron 7.0 Tron 5.5 Tron Nitron
Vcontrol Neo
Locktite is offline        Reply With Quote Quick reply to this message
Old 02-12-2021, 07:40 AM   #23 (permalink)
The leading edge is sharp ? Couldn’t I just use a piece of emery cloth and take the sharpe edge off ?
I am think I may buy some of these dampeners. If the low head speed performance is better they would be worth trying out. They say they can go down to 500 rpm and still good for high rpm.
Diabolo 700 BE, 600, Synergy-696, E5SS, Logo 600, 200, Goblin Raw 700, VCT, VBar, Egodrift, Scorpion, Kontronik, MKS, XPert, KST
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 02-12-2021, 05:04 PM   #24 (permalink)
It’s not that it is sharp but being the rigid core dampeners are so hard you run the chance of nipping the the o rings during install..These dampeners take some force to get into position .. deburring tool is what I was recommended to use by Augusto.. it worked out perfect..
Vcontrol Neo
Old 02-12-2021, 05:06 PM   #25 (permalink)
I appreciate the tip Locktite. I ordered the deburring tool you recommended.
Locktite likes this.
TDR’s / Diabolo BE’s / Diabolo SE / Diabolo UL / Goblin Kraken
VBC, VBCT, Kontronik, MKS, R2 buffer
Spencerkey is online now        Reply With Quote Quick reply to this message
Old 02-13-2021, 03:23 PM   #26 (permalink)
You don't need a deburring tool. An Exacto knife works excellent and does not roll any burr which can happen with some deburring tools, An angle closer to 20 degrees is also preferred over a 45 degrees, the insertion force decreases with a lower angle. This also applies to bores for bearings and bushings.
Helicrazy2 likes this.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is online now        Reply With Quote Quick reply to this message
Old 02-13-2021, 03:55 PM   #27 (permalink)
Ok you do that, I will stick with the deburring tool that I was recommended to use by Augusto (designer of these dampeners) .. it worked perfect and did the job correctly for me..enjoy your day and happy flying.
Vcontrol Neo
Old 02-17-2021, 11:58 PM   #28 (permalink)
They give a really awesome rigid direct response. While also running low head speed or doing autos absolutely like glass without resonance or weird behavior.
Normally there is quite some compromise and ugly break in periods with the stock dampening.
I have them on a Kraken, K580N, and bought a set for the Raw I'm building.
Xpert
Scorpion Power Systems
OnlyFineHelis. Family Run/Operated
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 02-18-2021, 01:31 AM   #29 (permalink)
Interesting as far as (tuning) in vbar goes, is it all that different from a main disc gain perspective? I also ordered some of these as I am going to be building a raw as well and setting it up same to my logo 700 build to fairly compare the two helis.
Old 02-22-2021, 10:55 PM   #30 (permalink)
Well I ordered the dampers and the de burring tool.
Old 02-23-2021, 04:02 AM   #31 (permalink)
This may help a few people out.. This video shows Augusto installing the rigid core dampeners in his avant Mostro.. yes an older video but a similar installation process can be used on the Kraken/ Raw/ 580 head (580 head was a little easier and no chamfer needed in head block)
http://www.avantrc.com/Products/Most...Insertion.html
jhamel and Spencerkey like this.
Vcontrol Neo
Old 03-17-2021, 02:28 PM   #32 (permalink)
Thanks for the video. It helps to know the correct method to install the rigid dampeners.
Old 03-19-2021, 01:27 AM   #33 (permalink)
imho save the money. Not worth the trouble. THey are a pain in the ass to install, getting them out is worse and honestly I like the feel of the stock dampeners better
dbirds2 is offline        Reply With Quote Quick reply to this message
Old 03-19-2021, 05:18 AM   #34 (permalink)
I finally received my little package from overseas. Installation (Trex 700) was easy and I like the performance. The Rex snaps a bit more into place. Absolutely no wiggely wobbely on the swash at any headspeed. So for Trex 700X Head I can recommend them! As always: YMMV
Netzferatu is offline        Reply With Quote Quick reply to this message
Old 03-19-2021, 06:03 AM   #35 (permalink)
Certainly not a waste of money.. if you follow correct install procedure they are very easy to install.
Vcontrol Neo
Old 03-19-2021, 07:13 AM   #36 (permalink)
I tried them on my Kraken 580. 30+ flights with them so far. I like them better than the stock 90/90 dampeners.
The o-rings came preinstalled. I had not seen the video, so I used standard Tri-Flow clear grease. I did not know about deburring the edges of the head block, so I did not do it. The dampeners inserted pretty easily to about 3/4 of the way in. Tight fit, but not excessively so until the last 1/4 of the way. I did not know about the recommendation to use groove pliers or an arbor press, so I just used 2 small flat plastic plates and brute force to get them in the last 1/4 of the way. I then inserted the blade grips without shimming between the dampeners and the blade grips. I tightened the blade grips a little bit at a time to gauge for preload. After the blade grips radial bearings abutted the dampeners, I believe I was only able to rotate the bolts about 1 turn to fully tighten. The point here is that there is some preload, but not too much preload to put excessive pressure on the blade grips bearings inner races. The tension on the blades grips felt optimal without shimming, so I left it alone.
I like the results. Before inserting these dampeners, I had given up fighting cyclic shakes which now disappeared with these dampeners. I was able to increase the head gains 18% to 24% per bank. I generally fly between 1900rpm to 2200rpm using RT-U 580 blades, but I was practicing autorotations at about 1425rpm. As expected, the response was slow at that rpm, but there were no annoying head shakes or wobbles.
My verdict: Expensive, but substantially improved performance.
OICU812 and Spencerkey like this.
Tron 7 (14S), Protos 700X Evo (14S), Kraken (14S)/Kraken 580 (7S)/Buddy 380 KSE (6S), Logo 550SX V2 (7S); YGE "T" ESCs; VBC Touch & Neo Vlinks, AGM Deep Cycle Batteries
Sims on Mac: Heli-X, neXt, AccuRC, RF9, Phoenix, AeroFly RC7 Ultimate
jhamel is online now        Reply With Quote Quick reply to this message
Old 03-19-2021, 12:29 PM   #37 (permalink)
not easy on mine after following exact instructions from video. Not a deal breaker but did not like them on flight performance, so I took them out and that was a pain in the ass. upgrades on these helis have never been a big fan of doing. With these dampeneres I got a huge amount of elevator tail bobble, which brought my gains down to 50 and it felt like shiaaat...... so I took them out.
Old 03-19-2021, 06:46 PM   #38 (permalink)
What heli did you run them in that you were experiencing this?
Old 03-20-2021, 12:46 AM   #39 (permalink)
goblin raw. The stock dampening on the rigid platform is soooooo much better for me.
Old 03-22-2021, 01:19 AM   #40 (permalink)
Interesting, I keep hearing how many people love these rigidcore dampers, but of course alas the Raw is a very new heli overall and seems not many also have really ran them on the Kraken (same head) either.
