Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
#1 (permalink) |
![]() Confused as usual...
![]() Can someone school me on my Jeti radio For example, setting the throttle output i.e., Idle 1, idle 2, idle 3 When setting throttle curve ( constant ) setting 80% out for idle 3 it says input 50% for all three idle curves, what does this value represent? Thank you.
Its all about having fun |
#2 (permalink) |
![]() I believe its just the centre point for this curve, if you select a 5 point curve or more you will notice the point percentages are in relation to where points are on the curve, IE 25% 50% 75% etc. It won't affect your curve as this is what is on mine as well.
Oxy 2 215- RIP / Oxy 2 215 sport / Oxy 3 Tareq 2018 / Trioxy 3 (aka Qube) / Oxy 4 / Goblin fireball / G380 / P380 Evo / G570 / G-stay tuned / eXo 500 / Jeti DS-12 |
#3 (permalink) |
![]() On my DS12 my throttle curves look like this:
For a constant flat curve it’s defined by one point (instead of trying to say from 0 to 100%) If you did a different type of curve there would be multiple “in” points and “out” points. In my screenshot, the “in” is in pink and is the point you’re modifying when you adjust the curve. Super easy. (On my other radios, I had to adjust 3-5 points to the same output to get a flat curve, PITA). The crosshairs shows the input and output values of the function, in my case 70%
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 |
#4 (permalink) | |||
![]() Quote:
Whiplash Turbine - Synergy N7 Gasser - Synergy E5SS - Goblin 500 - T-Rex 450L (x2) - Oxy 2 - Spirit FBL - Jeti DS-16 AccuRC to train my brain |
#5 (permalink) |
![]() Join Date: Oct 2010
![]() Thank everyone, I understand now.
#6 (permalink) | |
![]() Quote:
James and I have had a number of great conversations, he's a wealth of info. Having a resource like Helifreak is great when your unable to find a quick answer online. Just needed clarification on IN/Out - Thanks much
#7 (permalink) |
![]() Same here. I programmed computers for over 35 years. The programmability of Jeti is one of the things that drew me to it, in addition to the quality of Jeti's hall effect gimbles. You can do about anything you can imagine with Jeti.
