Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
#1 (permalink) |
![]() Trying to find some help for the layout of the controls, can not get them assigned correctly.
Has anyone done this? Please help. |
#2 (permalink) |
![]() I have this setup, what info do you require?
#3 (permalink) |
![]() Join Date: Nov 2006
![]() Busher PM sent
#4 (permalink) |
![]() I have loaded a file for you,
Unfortunately Helifreak does not allow jsn files to be loaded, I changed the extension to doc, so copy the file and change the .doc back to jsn and load it to your tx. I fly a ds16, mode1, so you may have to change a few of the tx inputs, however the outputs are set to spektrum. the momentary switch on my tx sg, operates panic mode. this simply pulls in a mix to put the unit back into safe mode, idle up 1 and 2 are on my sh switch which puts different head speeds on etc, hold is on my sb switch. hope this helps |
