Go Back   HeliFreak > R/C Electronics Support > FrSky
FrSky FrSky product discussion.
Like Tree2Likes
  • 2 Post By Helique
Closed Thread
Old 03-02-2021, 11:54 AM   #1 (permalink)
Default Archer R6 connection to FLB
Hi all: Just received the new R6 and I’m a bit confused as to how to connect S-bus to the FLB. There is a single wire in the provided cable loom labeled “s-bus out” which I assume would connect to the signal pin on the FBL. But how is the R6 supposed to get power?
Thanks for any help.
Helique is offline        Quick reply to this message
Old 03-02-2021, 12:04 PM   #2 (permalink)
In the manual it has a pinout diagram that shows which pins are positive and negative. Usually these get hooked up directly to the FBL's power bus.
— XLP Specter V1, XLP 550, Oxy 4 Max, Oxy 2, OMP M1 —
— Spirit GT — Egodrift & XNova, YGE & Scorpion, FrSky Horus OpenTX —
— WTB XLP Wraith for cheap —
xoexoe is online now        Quick reply to this message
Old 03-02-2021, 12:13 PM   #3 (permalink)
Also, which FBL? It will have instructions for how and where to connect SBUS to your FBL.
Old 03-02-2021, 12:21 PM   #4 (permalink)
Thanks for your reply. So I would run +/- leads from the FLB to any +/- servo channel pins on the RX?
Old 03-02-2021, 12:27 PM   #5 (permalink)
It’s a Bavarian Demon 3SX. It has a standard sbus channel using a servo connector. Issue is the R6 only has one wire in the cable loom that is marked sbus out. Not a three pin servo type connector. On my RX4-SB it has one servo channel (3 pin) that also serves as sbus out.
Old 03-02-2021, 04:54 PM   #6 (permalink)
I could see two options.
1. Do exactly what you're suggesting: Have the + and – wires go to two of any servo port's + and – pins, and have the unused signal (SBUS) wire go to the proper pin of the R6's 6-pin header. The instruction manual will say which one. You'll likely need to solder the servo wire's signal pin to the header's SBUS wire.
But personally I'd do option #2...
2. If the receiver came with a full 6-pin connector, just use that header thing. No servo ports needed. The instruction manual I found online for the R6 indicates which 3 pins of the 6-pin header are –/+/SBUS. So once you know which 3 pins (3 wires) you need from the 6-pin header, you can just solder or crimp your own 3-pin servo connector to make it fit the FBL port. If the receiver did not come with a full 6-pin connector, yell/swear/complain at FrSky, then purchase your own from AloftHobbies or wherever. (They have everything you could need... just ask if you don't find it in their online store.) But if Aloft doesn't have it, maybe try HansenHobbies.com
Old 03-03-2021, 10:31 AM   #7 (permalink)
Thanks much for your reply! Yes, I purchased the R6 from Aloft and it included two 6-pin cables; one has bare ends and one has connectors already crimped on. I think I’m going to go with your #2 suggestion. NOW my problem is: I can’t get the R6 to register! I follow the instructions carefully but when it gets to where I power on the R6, while pressing the bind button, the TX doesn’t see the R6. It just stays on “waiting” and the R6 LEDs just stay solid red/green. The TX has the latest firmware and ACCESS is enabled.
Old 03-03-2021, 11:35 AM   #8 (permalink)
Make sure your TX has the latest isrm firmware installed. I’m not talking about OpenTX software, but the RF board firmware. The TX firmware version should match the RX firmware version. At least that’s how it is on ACCST, not sure about ACCESS.
EDIT: It's probably not the issue, bit it -could- be depending on how old your RF board's firmware is.
Old 03-03-2021, 12:31 PM   #9 (permalink)
Make sure your TX has the latest isrm firmware installed. I’m not talking about OpenTX software, but the RF board firmware..
THAT WAS IT!!!
Thank you so much! I tell you, if it weren’t for members like you on the forum, I wouldn’t be in this hobby today. Thanks again!
PaoloFCantoni and xoexoe like this.
Old 03-04-2021, 10:41 AM   #10 (permalink)
1. Do exactly what you're suggesting: Have the + and – wires go to two of any servo port's + and – pins, and have the unused signal (SBUS) wire go to the proper pin of the R6's 6-pin header...
Would you possibly know what size that 6-pin connector is? I’d like to order a cable with longer wires. JST-SH micro? 1mm? Thanks.
Old 03-04-2021, 10:56 AM   #11 (permalink)
Not sure. ALoftHobbies would know.
FrSky uses different pitches for different receivers. Is there a size reference on the instruction manual?
Old 03-04-2021, 11:44 AM   #12 (permalink)
Hi and thanks. No reference in the “manual” or anywhere on the net that I can find. I’ll check with Aloft, thanks again!
Old 03-04-2021, 10:33 PM   #13 (permalink)
No luck with Aloft I’ll post a new question.
Closed Thread
