Like Tree2Likes
  • 1 Post By Rabid121
  • 1 Post By Vinger
Old 03-15-2021, 06:51 AM   #1 (permalink)
Default Mini Blue Twitching Servos
Finally got my 450 setup with an old blue mini and Futaba radio. These servos are Hitec MG's. Front 2 are new and rear is an older one. This is at power up. Once I start using them they get better but still, when I go up and down on the collective and servos are NOT in perfect unison. First video is on power up. Second video is after moving the collective a few times.
Mikado Twitching Servos (0 min 23 sec)
Mikado Servo's not in perfect unison (0 min 15 sec)
~Cliffman~ is offline        Reply With Quote Quick reply to this message
Old 03-15-2021, 09:35 PM   #2 (permalink)
What are you sing for power supply on the helicopter? Can you access the log and post it here?
VControl
Old hand at Planks
Peter
Old 03-16-2021, 06:14 AM   #3 (permalink)
The ESC is a Hobby King Blush-32 with BEC. Thanks!
Old 03-16-2021, 10:07 PM   #4 (permalink)
It could be that the BEC of the ESC is not enough to power the servos. Which servos are you using? The VBar system can only use digital servos.
VControl
Old hand at Planks
Peter
Old 03-17-2021, 08:49 AM   #5 (permalink)
The Servo's are Hitec HS-65MG's
Old 03-17-2021, 12:38 PM   #6 (permalink)
looks like the esc is junk and the bec cant handle the servos.
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 03-17-2021, 01:13 PM   #7 (permalink)
I'll check the voltage from the ESC's BEC. Needs to be above 4.5 I think
Old 03-21-2021, 09:09 PM   #8 (permalink)
Voltage is good at 4.95 volts.
Old 03-21-2021, 10:31 PM   #9 (permalink)
That is very low and the back EMF from the servos can be problematic, need at least 6V to be safe.
VControl
Old hand at Planks
Peter
Old 03-22-2021, 07:19 AM   #10 (permalink)
I'm right at the low end but still shouldn't cause this issue.
Name:	Hitec HS65-MG Specs.JPG
Old 03-22-2021, 08:06 AM   #11 (permalink)
... did you check the voltage under load? just move the sticks a bit.... you will see most probably going the voltage lower then the specs of 4.8V.... this is supposed to be the reason for the odd behaviour. under real load the voltage will dip even much deeper and causing a brownout => vbar reboot => crash.
Ciao
Michael
some minicopters & Logos, YGE, Egodrift, Spirit 2/RS/GT/GTR, Jeti DS-12/Spirit Ed.
Rabid121 is offline        Reply With Quote Quick reply to this message
Old 03-22-2021, 09:07 AM   #12 (permalink)
believe what you want, that esc's bec is no good. especially under load.
spend a couple bucks and get a budget used hobbywing esc with program box and your life will be better.
Old 03-22-2021, 09:40 AM   #13 (permalink)
Ciao
Michael
Agreed with the voltage. I'll replace the ESC but... I don't think that's causing the issue with the servo. Did some more testing yesterday and I think it's somehow related to trims. I hooked it up to the Mikado software (Version 4.0) and went through the setup tabs (Not a new setup) and when I get to trims the back servo (#1) started to vibrate like its fighting to get to it's desired position. while I was observing this I noticed the servo was getting hot after about 30 seconds so I cut the power. Maybe I did something wrong during the setup. What do you think? Maybe I should start over with a new radio model and new Mikado setup???
Old 03-22-2021, 10:17 AM   #14 (permalink)
... i do not remember this old Mikado soft version anymore, so no idea. why not bring all to a more recent version? (5.3.x iirc).
of course could be defective servo, binding etc etc etc too... but this esc will be a source of trouble for sure. and you'll never know what different devices will do when operated at/below voltages specs limits.
~Cliffman~ likes this.
Old 03-22-2021, 10:47 AM   #15 (permalink)
I have 5.1 but it has error messages when I try to access my old Vbar. Can I update the old Blue vbar so it will work with the newer version do you know?
Old 03-22-2021, 10:38 PM   #16 (permalink)
https://uroehr.de/vtube/cat/old-v5-vbars-archive-
All the videos relating to the older devices, yes you can update to at least V5.3.
Rabid121 likes this.
VControl
Old hand at Planks
Peter
Old 03-23-2021, 02:08 AM   #17 (permalink)
yes, as Vinger already wrote! and i would really advise to go to latest software available for the legacy vbar... this one was really working great! and best would be to start from scratch with a new model. it's generally done in some minutes and worth the effort!
Ciao, good luck
Michael
btw: ... just checked... it's 5.3.4b... available here: https://www.vstabi.info/en/V53_software
