Old 09-18-2019, 11:05 AM   #1 (permalink)
Default Krönen Sie mich König.
A massive 12N8P switched reluctance machine rewind projeckt . Complete with slot wedges and a dedicated controller.
ID:	816185Click image for larger version
ID:	816187Click image for larger version
Christian und Konstantin bin ich hier.
"Diese Flugzeuge werden von Clowns entworfen, die von Affen beaufsichtigt warden....."
1BOHO is offline        Reply With Quote Quick reply to this message
Old 09-18-2019, 12:15 PM   #2 (permalink)
Default Die Krone
Christian is here https://www.academia.edu/37532339/A_...?auto=download
This is clearly an ABC wind with 8 salient poles. I will try shifting for the 4th harmonic between the two SL machines. Maybe ABCx4 to go with it. The machine suffers no rotor losses so the slot, winding, and frictional losses are to be mitigated.
Other Ideas?
Old 09-18-2019, 06:33 PM   #3 (permalink)
So we see this unipolar coil arrangement for each phase .The corresponding SR drive topology has 6 motor outputs.The main advantage of this converter is its ability for independent control of each phase.
ID:	816301   Click image for larger version
Old 09-18-2019, 10:53 PM   #4 (permalink)
ID:	816435Click image for larger version
The original; wind was 144 turns. The copper including end turns was approx.1.656 kg. The stator is 2.381 kg.The stator ar is 140mm x 45mm
@ChX2
You see open slots with only a notch detail for slot wedges. I know you like big iron or none at all. Maybe the 140 diameter motor will win the speeders Schneider cup.
To know him Look up Feed Forward Torque Control Of A Switched Reluctance Motor Based on Static Measurements
H. Bausch and Konstantin Kanelis.
Old 09-22-2019, 01:18 PM   #5 (permalink)
Default Recount!!
182 turns so 364 strands of 23 ga wire in the slot. 93.912 mm^2. The slot area is 196 mm^2. Fill was approx 48% I think I will wind for around 50 turns of 17Ga. I have the dedicated controller but would like to build a sensorless one. This one uses an optical encoder and gray code for accurate positioning.
Ive set up the propeller chip to drive a sinusoidal microstep. Id like to see what the harmonics look like on the scope. The chip is a LM339.
ID:	817071   Click image for larger version
ID:	817073   Click image for larger version
Name:	lm339 unipolar bridge.png
Old 11-13-2019, 06:44 PM   #6 (permalink)
After talking with my colleague a SRM specialist Dr. Konstantin Kanelis. He has directed me how to accurately capture the parameters for the model of the SRM machine. I need a jig that will let me turn the motor to a predetermined mechanical angle and lock it there. Then you run current with an isolated transformer and record the current at the predetermined angle. From this you can build the necessary parabolic function based on mechanical angle and current. To make implementing the model and driving this machine easier I have gathered all the necessary pieces to build a RPC for a kitchen lab. The RPC allows us to run an industrial 3 phase VFD and other 3 phase components from a 110 wall socket. The Industrial VFD has many more features and adjustments than our hobby drives. With it I can drive all types of machines and implement all kinds of commutation schemes DTC, CFC, V/HZ, etc. This is a valuable bench device in the right hands.Its very similar to a leonard ward setup! The IM shown is nice with 24 slots open cage and its aluminum so it is light. If the pole count agrees Ill implement the phase shifted Y-D wind on this machine. A cleaner sine would do wonders here as it would be supplying my 3 phase devices. If you've ever priced 3 phase power into your home you will appreciate this for sure.
Im leaving you all a schematic. Lets see who does anything with my blathering. Practice recycling and you don't pay much for the complimentary components or even the pony motor!
I wonder should I run the snake oil in it?
Somewhere along my travels in the hood I learned something..... a lesson that might be taught on field weakening and why a surface mounted PM machine has speed limitations.
Above base speed, the applied voltage is the maximum and the back-EMF exceeds the
applied voltage. Consequently the back-EMF has to be reduced to produce torque in
the constant power region. In a SPM machine stator current has to be used for this and this typically makes a SPM machine not the ideal candidate for flux weakening. Maybe a bright light from raytheon can spin off this. Even though they specialize in defense and electrical warfare not rotating electrical machines.
https://www.semanticscholar.org/pape...7e6d049e7bb8c9
This is where Benz is headed with e mobility. Big wheel$ rule. 24's on front and 26's on the back. I guess Benz is down with the hood . What does Raytheon know about the starter in this.......
ID:	825859   Click image for larger version
ID:	825861   Click image for larger version
ID:	825869   Click image for larger version
Old 11-13-2019, 11:18 PM   #7 (permalink)
Here is a close up of the pony candidate. A nice COOL open body to work with. Has full ball bearings and a 24 slot stator
Old 11-14-2019, 02:22 AM   #8 (permalink)
CHX2
This is just for you from the ABB corporate research center at NC State. More on pole shaping in the flux switching machine.....
https://www.academia.edu/28680300/Co...r_Pole_Shaping
Enjoy.
Old 11-16-2019, 01:52 PM   #9 (permalink)
Lets get pony prepared for a fscw.
Old 11-16-2019, 01:57 PM   #10 (permalink)
The first thang we gone do in da hood is break the teeth's edges on the iron.
Old 11-16-2019, 02:12 PM   #11 (permalink)
The I'll show you the hood conceived fixture that is needed to take static measurements to build the commutative parabolic function for Kostas feed forward SRM commutation model for this particular SRM. The fixture will have to be stout! Even for the smaller machines like you run in a rc heli. My 4638 stall torque at Preece is quite enuf to snap something. An arm would be pie!!! Keep sticking ya gloved hands down there if you want to. If its get caught up somehow its over.
Old 11-16-2019, 07:53 PM   #12 (permalink)
Broke and needs > 100 turns running of the line. That's a lot of orthocylic wrapping ahead.
ID:	826425   Click image for larger version
Old 11-20-2019, 11:41 AM   #13 (permalink)
Forum excel applets are great for general approximations but engineers and machinist don't work of approximations they work off the NUMBER! and you gotta know what the number is. Create an excel winding applet that uses these real formulas we actually use.So you really know what that number is. It requires mathematics, and measuring devices ,radius gauges,precision dowels,calipers,gap gauges, etc.....please enjoy the realness of slot area calculation. The other way in cad is to create the I-mate part to the stator and check its area, which would resemble an intelligent stator cage. That would be the way to design that and ensure bars with100% fill
Holla back....
Old 11-20-2019, 05:21 PM   #14 (permalink)
So you see the IM stators I have have slot style "D" The math is here.
Qu=h/2(b1+b2)+h'/2(b0+b1)
Old 03-04-2021, 09:00 AM   #15 (permalink)
Default Wo ist Ihr Drehphasenkonverter ?
SRM Dr. K.K. suggest reverse engineering the drive which was designed for a washing machine which to us runs a relatively relatively high voltage and low amperage so while it will drive a motor with lower turns count its wimpy fet wont handle what we do amp wise. The IC has no identifiers so re work is a task. You see I have the rotary phase convertors. One is already built for 20 hp 240v 3 phase support of a single 240 line .
The motor is a 20 hp Blador The other will support 10 hp which is plenty of overhead for a 5hp industrial VFD. Having that on my bench will allow testing of many concept motors like ISCAD, IM, SRMs , Synchronous SRM's, PMDC, PMACS and quite possibly the flux switching machine I designed. But we can definitely drive this SRM with the fully programmable VFD.
Ich kann die Wicklungskrone des Königs definitiv verbessern, aber statische Messungen müssen an der neuen Maschine durchgeführt werden, um zuerst in die vfd Motorparametertabelle einzugeben. Dazu ist ein Indexer mit einem Gradrad und einer isolierten Transformator-Stromversorgung erforderlich.
Support the IEEE
1B.
ID:	907259   Click image for larger version
Name:	56608-baldor-em2334t-20-hp-super-e-electric-motor-230-460v-3ph-256t-frame-1760-rpm-3.jpg
ID:	907267   Click image for larger version
Old 04-18-2021, 09:54 AM   #16 (permalink)
I want to redirect this thread a little to open it for sharing alternative energy projects or just repurposed motors salvaged from devices on the way to the dump. It makes not a lot of sense for us to pay upward of 400.00 for hobby machines and then watch motors like this thrown away in the trash. Some people that salvage have figured out that they can post the motors online and get more than the 15 cent a pound they get for the motor at the yard. They are selling them so cheap I cannot resist. You can build a very large coaxial or chopper, perhaps a scale speed plane or another various in wheel or renewable energy project.
Lets show we can do something useful with this. Its going in the trash at a phenomenal rate. That's crazy in an ever becoming electrified world. Were all Kings when we recycle. This also means that possibly you could rewind your appliance for better efficiency and cost savings. Don't just throw it away and buy new. We cannot sustain over the long haul like that.
ID:	913649   Click image for larger version
Old 04-19-2021, 01:08 PM   #17 (permalink)
The poorly filled 18 tooth stator is 207 x 24 mm, so its in "our" size now.
Old 04-19-2021, 01:24 PM   #18 (permalink)
The 24 pole rotor rotor with a ferrite inner ring and physical allocations to facilitate the electro clutch.
ID:	913893   Click image for larger version
Old 04-19-2021, 02:04 PM   #19 (permalink)
The electro clutch is merely a 120 volt 60 hz magnetic coil and spring arrangement. It could be useful in many projects.
ID:	913901   Click image for larger version
Old 04-19-2021, 02:05 PM   #20 (permalink)
18N24P
