Like Tree3Likes
  • 2 Post By vvv850
  • 1 Post By AndyO
Old 04-26-2021, 07:31 AM   #1 (permalink)
Default REX rcvrs
First time user of a REX rcvr (REX7) and having issues being able to change to EX Bus to be able to work with my FBL (MSH).
Going through the bind process, I put power on E1, plug in bind plug and it binds no problem. Leaving things set like this, I go to model-device explorer and I can see the REX7. When I select it, the little menu option to change to EX Bus doesn't show above General Settings where it would normally be. I am able to change the output period to Auto.
Is there some sequence I screwing up? This whole thing is not helping my 2-day long migraine, lol.
Any assistance would be appreciated.
Old 04-26-2021, 07:54 AM   #2 (permalink)
Go to alternative pin config. Exbus will be there.
vvv850 is offline        Reply With Quote Quick reply to this message
Old 04-26-2021, 08:10 AM   #3 (permalink)
I was able to change E2 output to EX Bus and things work with rcvr plugged into E2. Is that the correct way?
-Ben
Old 04-26-2021, 08:10 AM   #4 (permalink)
I will look there.
-Ben
Old 04-26-2021, 08:14 AM   #5 (permalink)
That is where I changed E2 to EX Bus. No option to change Ext to EX Bus. For R3s, which is what I usually run, you plug rcvr into the ext port. Is that not the same for REX?
Sent from my SM-G988U using Tapatalk
Old 04-26-2021, 08:54 AM   #6 (permalink)
This is for REX receivers:
Name:	Screenshot 2021-04-26 165145.png
Only E1 and E2 can be set to Exbus
apostolosnt and jrman83 like this.
Old 04-26-2021, 09:09 AM   #7 (permalink)
Thanks. Get so used to using one type rcvr, you make assumptions. Not safe to assume.
-Ben
Old 04-26-2021, 09:20 AM   #8 (permalink)
I usually use REX3 receivers in my helis. Or the Spirit RS.
Old 04-26-2021, 01:40 PM   #9 (permalink)
For the Brain2, you only change the E.. pins to Exbus Ben, so E1 and E2 only on the Rex7 👍
Sent from my SM-G981B using Tapatalk
jrman83 likes this.
AndyO is offline        Reply With Quote Quick reply to this message
