Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree40Likes
Old 05-03-2021, 11:03 PM   #41 (permalink)
I believe your idlers are on the wrong side of the mount if I’m not mistaken Ken.
Freeskiken likes this.
AMA # 1121783 CITIZEN 816
You cant pass if you choose to follow
scssniper74 is offline        Reply With Quote Quick reply to this message
Old 05-03-2021, 11:12 PM   #42 (permalink)
Thanks. Yes I saw that when I went to put them together.
I think I have it right now. The belt tensioner pulley lines up with the raised idler pulley.
Sent from my SM-G960W using Tapatalk
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 05-03-2021, 11:15 PM   #43 (permalink)
Lookin good! I’m about to get a motor mounted on mine.
Old 05-03-2021, 11:30 PM   #44 (permalink)
Awesome !!! Post a picture. What motor ?
Diabolo 700 BE, 600, Synergy-696, E5SS, Logo 600, 200, Goblin Raw 700, VCT, VBar, Egodrift, Scorpion, Kontronik, MKS, XPert, KST
Old 05-03-2021, 11:37 PM   #45 (permalink)
Had these layin around so figured I may as well use em.
Old 05-04-2021, 09:04 AM   #46 (permalink)
Awesome !! Good choice !! It should have tons of power.
Old 05-04-2021, 09:52 AM   #47 (permalink)
I think that power combo would pull stumps and then some!
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 05-05-2021, 07:24 PM   #48 (permalink)
Scratch that, caliper not 0'd
Oxy 3 Tareq - BKservo/X-Nova Motor/Hobbywing ESC
Mikado V-Control
Blupup is offline        Reply With Quote Quick reply to this message
Old 05-05-2021, 07:27 PM   #49 (permalink)
46mm end to end
Fastnine is offline        Reply With Quote Quick reply to this message
Old 05-10-2021, 11:52 PM   #50 (permalink)
Too busy lately to build. But had a few minutes tonight. Changed out the servo bracket tonight that was stripped with a new one. Put the stickers on and mounted the lower carbon frame pices. Make sure when you remove the stickers from the paper you start in the middle corner otherwise you can tear the decal.
Old 05-11-2021, 11:29 AM   #51 (permalink)
Hard to tell from the pic, but it looks like the retaining screw for the front landing gear isn't flush. This will cause issues when you add the battery hatch supports.
I think the newer kits have countersinks on both frame sides, but there isn't enough material so the screw doesn't sit flush with the frame.
I moved the screw to the other side of the mount (had to grind off a couple of mm's from the screw)
Weule is online now        Reply With Quote Quick reply to this message
Old 05-20-2021, 10:07 PM   #52 (permalink)
Mounted the landing gear.
Old 05-20-2021, 11:18 PM   #53 (permalink)
6mm Scorpion bullets installed
Old 05-20-2021, 11:51 PM   #54 (permalink)
I have the motor installed. But the motor belt is below the main pulley. I installed the pinion against the motor bearing support. I guess I need to move the pinion up higher so the belt does not go below the main pulley? Edit: It was late last night so I quit, I will remove the motor and raise up the pinion so my belt is higher on the main pulley.
Old 05-24-2021, 06:10 PM   #55 (permalink)
I took the motor mounting assembly out and back a couple of times. I either had the main belt too low or too high. I found 2mm to 2.10 mm spacing between the pinion and the lower bearing and now the belt is sitting at the bottom of the main pulley. Just barely up from the edge of the main pulley.
Old 05-24-2021, 06:39 PM   #56 (permalink)
Mounted the ESC on the mount. I like the caps facing up. I always fix the wires to the side of the ESC. Then I have a extra EC5 connector and then my series cable. This way the ESC wires do not bend back and forth every time you plug the batteries in also in a crash if the batteries eject it just pulls the cable off instead of ripping the wire out of your ESC. Something Dmitry taught me on the first Logo 600SE I built.
Old 05-24-2021, 06:40 PM   #57 (permalink)
I always tape my motor wires to make sure they can't short.
Old 05-24-2021, 09:10 PM   #58 (permalink)
Tail is assembled
Old 05-24-2021, 09:48 PM   #59 (permalink)
Tail case is assembled
Old 05-24-2021, 10:29 PM   #60 (permalink)
Massive boom !!!! Assembled the tail case on to the boom.
