Old 05-05-2021, 03:12 PM   #1 (permalink)
Default programing rc cars onto jeti ? possible?
I have a hoist of crawlers and 1/14 trucks. I would love to get them off my dx6r and onto the ds12. Most of it is very straight forward... My big issue is that I would like to be able to "flip" a switch to get into reverse. Having to balance the left stick in the center is a challenge.. the trucks tend to shoot off in a direction if I am not careful. I would want to set them up similar to an airplane where 0 throttle is the bottom of the stick. This is fine to do, but then I cant get reverse to work. Any tips?
MotorG525 is offline        Reply With Quote Quick reply to this message
Old 05-05-2021, 03:41 PM   #2 (permalink)
Of course its possible as you have a completely programmable radio
My suggestion would be to setup a "flight" mode which reverses throttle but keeps all other channels normal but with jeti there are many ways to skin the proverbial cat so choose your poison.
I am sure more ideas will be mentioned so try them all out and pick your favourite
Chippie13 is offline        Reply With Quote Quick reply to this message
Old 05-05-2021, 04:19 PM   #3 (permalink)
I used my Jeti with a TRX4 Crawler and a R7Nano.
To avoid the throttle issue with the left stick I just used the right stick for throttle and the left for direction. This way it doesn't matter if the left stick moves up and down.
I think that you can also use a switch for flight modes. One mode has throttle from 50 to 100 and the other from 50 to 0.
vvv850 is offline        Reply With Quote Quick reply to this message
Old 05-06-2021, 01:21 AM   #4 (permalink)
Yup, definitely possible and Chippie's suggestion of using a flight mode is the way I would do it too. Create flight modes for forward and reverse, then in Fine Tuning -> Function Curves, set throttle to be per flight mode instead of global, and edit the curve so it's using 50 to 100 for one flight mode, 0 to 50 for the other.
If you also want the radio to announce "Forwards" and "Reverse" as you change flight modes, use Teros' text to speech service to generate those audio files, and add them to each flight mode: https://www.rc-thoughts.com/tts/.
And finally, if you want the radio to prompt to ensure you're in forwards when you first start, in Advanced Properties - Sticks/Switches Setup, set the "Required pre-fl. pos." for your flight mode switch. With that set it won't bind to the crawler until you're in forwards mode.
Old 05-06-2021, 08:36 AM   #5 (permalink)
sick.. gonna order a new rx to retry this with. will let you all see how it goes once its together
Old 05-06-2021, 01:21 PM   #6 (permalink)
I don't know much about Jedi, does it have a built in FBL?
Anyway, you might be interested to know that after getting in to helicopters, I have put Gyros on all my RC cars.
I started by re-purposing discarded Align 3GX units. This probably works with any FBL that has a separate rudder section. Use the rudder gyro to control the steering servo.
Eventually I got rid of the heli units and went with the dedicated Futaba "Grip" car gyros and high-end steering servos. This really transformed all my RC cars!
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T 2018 Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 05-06-2021, 04:09 PM   #7 (permalink)
I thought about doing the same with another brand radio, but then I thought about the extra wear and abuse and got a Flysky Fly Sky #GT3B, it has a 10 model memory and its $50, perfect for my car bashing needs. Receivers are dirt cheap too.
yakky is online now        Reply With Quote Quick reply to this message
Old 05-06-2021, 09:57 PM   #8 (permalink)
That is just for rock crawlers and 1/14 tamiya truck / construction type rc so no gyros. I keep the pistol grip radios for the bashers / speed cars. Tried messing with the flight modes and got lost. Might just use the right stick
Old 05-07-2021, 12:54 AM   #9 (permalink)
It's worth sticking with it, flight modes are a really useful feature once you get the hang of them. Harry Curzon has a great introduction video on YouTube that's well worth a watch. At 7:30 he starts programming separate function curves on separate flight modes, which is pretty similar to what you want to do with throttle:
Jeti - using Flight Modes (18 min 46 sec)
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 05-07-2021, 09:28 AM   #10 (permalink)
not giving up yet, the flight modes themselves work as on the switchs . I just could get them do do what i want, thus i realized i dont have function curves installed. So i purchased that and will re try tonight
Old 05-08-2021, 12:43 PM   #11 (permalink)
Pretty sure i got it, had to use the dual rates as well. Once my rx gets here ill test it out and make a video to help others
