Go Back   HeliFreak > R/C Simulators Support > AccuRC Flight Sim
AccuRC Flight Sim AccuRC Flight Sim Discussion
Like Tree1Likes
  • 1 Post By Johnny31297
Old 05-13-2021, 03:18 PM   #1 (permalink)
Default This Isnít Doing What I Imagined
I have been playing around trying to work out if it is possible to switch between RPM1, RPM2 and RPM3 with a single 3-position switch.
I was already aware that a 3-position switch is actually two 2-position switches.
I had just about given up as impossible when I noticed that you can actually assign two buttons to a function.
I thought great, so if I add button 2 and button 3 to each of the RPM functions then I will be able to set it up so each only comes on with the correct combination of button 2 and button 3.
This is what I ended up with
I imagined the two buttons being ANDed together.
But it doesn’t seem to work like that and if I go to a helicopter on the workbench to see if it works, it doesn’t and when I return to the functions screen all the Button 3s have been changed to Button 2s.
So this begs the question, what is the PLUS sign for on the functions page if adding extra controls has no effect.
Cheers,
Nigel
nheather is offline        Reply With Quote Quick reply to this message
Old 05-13-2021, 03:22 PM   #2 (permalink)
What radio are you using?
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 / Kraken 580
JimJW is offline        Reply With Quote Quick reply to this message
Old 05-13-2021, 03:55 PM   #3 (permalink)
I'm actually using a Real Flight Interlink DX controller - I appreciate that I might be able to do something on the radio side with a programmable radio.
My real question here is what is the purpose of being able to add multiple buttons to a function as in my screenshot.
I'm not sure what it is trying to do - also it will let you add Buttons 2 and 3 to a function (as you can just about see) but if you go off that page and come back they will have both changed into Button 2.
Also where are the virtual FBL settings - I saw them yesterday but I can't for the life of me find them again.
Cheers,
Nigel
Old 05-13-2021, 04:59 PM   #4 (permalink)
Why don't you just use the preset we made for the Interlink DX?
In the flybarless system. Click it in the workbench to access all parameters or click the FBL quick config in flight mode to change the most important stuff.
Johnny31297 is offline        Reply With Quote Quick reply to this message
Old 05-13-2021, 05:02 PM   #5 (permalink)
Worked out both my questions, well sort of.
Still no idea what adding two buttons to a function does.
But I've worked out the 3-Position RPM. Basically you setup RPM1 and RPM3 and leave RPM2 unassigned. Then the software just assumes that if you haven't got RPM1 or RPM3 selected then you must want RPM2.
Works a treat.
And the FBL settings - well funnily enough, go into Workbench, select the FBL controller from the parts on the left and there are the settings - knew I'd seen them.
Cheers,
Nigel
Old 05-13-2021, 06:27 PM   #6 (permalink)
Location: Perth, Western Australia (the most isolated (AND COVID FREE!) capital city on earth!)
Did you find my post from January this year about how to set up three-position switches?
If not, it comes to the same mechanism.
However, I, too, am intrigued by what adding two buttons to a function does? Is it a Boolean OR function?
Paolo
XLPower 700, ALIGN 550L (beater), PrŰtos MAX V2 Leggero 700 & Evoluzione 800 (RCHN #803 - joined just before they shut up shop!)
PaoloFCantoni is offline        Reply With Quote Quick reply to this message
Old 05-14-2021, 04:12 AM   #7 (permalink)
this explains how the functions menu works
AccuRC Transmitter Functions menu (3 min 59 sec)
[email protected] Direct Email
[email protected] AccuRC Support
https://discord.gg/ftCKT8U AccuRC Discord Server
Ade_Law is offline        Reply With Quote Quick reply to this message
Old 05-14-2021, 04:36 AM   #8 (permalink)
I did watch this video first - it didnít help.
Some constructive criticism.
It shows how to setup RPM2 and RPM3 on a 2-Position switch. What about RPM1.
The video does not show it working in the sim.
And I think that keep referencing throttle curve is a bit confusing for those (probably the majority) trying to use a 3-Position switch.
As I have found (as posted above) is when using a 3-Position switch you need to realise that it is actually TWO 2-Position switches, letís call them Switch 1 and Switch 2.
So if you put Switch 1 on RPM1, Switch 2 on RPM3 and you leave RPM2 unassigned then when neither RPM1 nor RPM3 are switched on the sim fills in the blank and assumes you must want RPM2.
Works a treat but not intuitive, nor is it covered in the video guide.
Next question, I have the RPM switch working a treat, when flying I can hear the rotor pitch change as I switch through the three settings. BUT where do you actually set what those RPMs are, Iíve not found that in the sim yet.
So say I had a small heli and I wanted to try 2800, 3000 and 3200 where would I enter those for RPM 1, 2 and 3
Cheers,
Nigel
Old 05-14-2021, 06:32 AM   #9 (permalink)
In the ESC, because that's what governs your RPM
nheather likes this.
Old 05-14-2021, 09:07 AM   #10 (permalink)
Because it is totally wrong. I assumed that if I selected the Interlink DX transmitter and Interlink DX profile it would all be pre-set up.
But everything is wrong.
I have reported this back to Ade.
This is what you get when you connect up an Interlink DX controller
That is not what the latest version of AccuRC sets up, even the four basic stick assignments are wrong.
It's not a big deal, I just thought that with a named device with a matching profile it would all be done for me.
Cheers,
Nigel
Old 05-14-2021, 09:09 AM   #11 (permalink)
Cool, spot on, thanks for the help.
Cheers,
Nigel
