Go Back   HeliFreak > For Sale Forums KNOW your buyer/seller ratings! No Price bashing. NO FIREARMS > Electric Helicopters - Only E-Helis
Electric Helicopters - Only E-Helis *No Commercial Ads - E-helis Only
Old 05-31-2021, 06:30 PM   #1 (permalink)
Default OXY 3 285 Stretch Plus Large TE Parts Lot/Two NIP Canopies
I have an older Oxy 3 (Kit 2) for sale. It has the main frame on it prior to the new sport frame and Tareq frame from 2018. The motor in it is a EOX 2214-4100KV (3s-4s) with a 10T, 11T and 14T pinions (asking $25.00 shipped). I also put KST215MG on cyclic and a MKS HV93i on the tail with a Castle Creations Talon 35 ESC (asking $SOLD) and an Ikon.
When original built as a 255, I had a mishap on a spool up on the fifth or so flight and bent the tail boom, scrapped the original carbon fiber Lynx main blades and damaged the canopy.
I then decided to turn it into a 285 stretch, and put a stretch boom on it, new main shaft, spindle shaft and main gear on it with Lynx 275 plastic yellow main blades. After going over the heli, I flew it three or four more times with no further incident. However, I never took the time to dial in the Ikon and flight settings and the heli has since sat on the shelf.
In aspirations to fly the heli a lot more, I purchased a whole bunch of Tareq Edition orange anodized parts to put on the heli. But never got around to making those changes either. (See attached list.)
SP-OXY3130 Tareq Edition Aluminum Tail Servo Mount Set Orange (On Heli) SOLD
SP-OXY3-107 285 Stretch Tail Boom (NIP) SOLD
SP-OXY3-108 285 Stretch Tail Belt Spare (NIP) SOLD
SP-OXY3-144 Landing Gear White (2 pc) (NIP) SOLD
SP-OXY3-104 Carbon Copolymer Anti-Rotation Guide (NIP) SOLD
LX1807-B Main Grip Black Pro Edition (NIP) SOLD
SP-OXY3-112 Tareq Edition Ultra Main Grips Orange (Opened Never Flown) SOLD
SP-OXY3-116 Tareq Edition Main Shaft Bearing Block Middle Orange (NIP) SOLD
SP-OXY3-115 Tareq Edition Main Shaft Bearing Block Upper Orange (NIP) SOLD
SP-OXY3-118 Tareq Edition Motor Mount Orange (NIP) SOLD
SP-OXY3-121 Tareq Edition Boom Clamp Stiffener Orange (NIP) SOLD
SP-OXY3-119 Tareq Edition Canopy Mount Orange (NIP) SOLD
SP-OXY3-133 Washer Orange (20 pc) (NIP) SOLD
SP-OXY3-128 Tareq Edition Tail Bell Crank Orange (NIP) SOLD
SP-OXY3-123 Tareq Edition Tail Rotor Assembly Orange (NIP) SOLD
SP-OXY3-117 Tareq Edition Main Shaft Bearing Block Lower Orange (NIP) SOLD
SP-OXY3-138 Tareq Edition Motor Mount Stiffener Orange (NIP) SOLD
SP-OXY3-065 Canopy Grommet (4 pc) (NIP) SOLD
SP-OXY3-155 Tail Case Flanged Bearing 3x7x3 (2 pc) (NIP) SOLD
SP-OXY3-067 Main Shaft Bearing Block Service Bag (NIP) SOLD
SP-OXY3-114 Tareq Edition Ultra Swashplate Black and Orange (NIP) SOLD
SP-OXY3-124 Bell Crank Support Black (NIP) SOLD
SP-OXY3-111 Tareq Edition Center Hub Black (NIP) SOLD
SP-OXY3-163 Tareq Edition Guide Pushrod Support (NIP) SOLD
SP-OXY3-024 Tail Rotor Hub Spare (NIP) SOLD
SP-OXY3-004 Main Blade Grip Dampeners Service Bag (2 Set) SOLD
SP-OXY3-018 One Way Sleeve Set (NIP) SOLD
SP-OXY3-080 Tail Shaft 15T (NIP) SOLD
SP-OXY3-051 Break Away Canopy Set (NIP) SOLD
SP-OXY3-037 Servo Linkage (2 sets) (NIP) SOLD
SP-OXY3-045 Tail Servo Mount (NIP)
SP-OXY3-052 Swashplate Leveling Tool (Opened) SOLD
SP-OXY3-001 Steel Main Shaft (1 pc) (Opened Never Used/Other In Heli) SOLD
SP-OXY3-019 Main Gear (1 pc) (Opened Never Used/Other In Heli) SOLD
SP-OXY3-003 Carbon Steel Spindle (1 pc) (Opened Never Used/Other In Heli) SOLD
Lynx OSP-1150 H2-M2 Nut (4 pc) (Opened Never Used/One on Heli) SOLD
Besides including the above listed items I will also include a set of Zeal 285 Carbon Fiber Main Blades (Opened Never Flown), a set of Lynx yellow 275 plastic main blades (Flown On The Heli) SOLD, the Talon ESC SOLD and the motor. 11T and 14T Pinion. Miscellaneous bolts, nuts, screws, washers, blade holder, original swash leveling tool, etc. (See attached pictures.)
I will also include the original damaged canopy. But I have also purchased two NIP canopies that I will include as well. SP-OXY3-167 Green Canopy (SOLD) and OSP-1201, which is the new standard canopy for the OXY 3 SOLD (See attached pictures.)
With the NIP parts, new canopies and new Zeal blades, there is over $400 in spares alone.
Original Ikon. The USB port does not work. Because plugging into it one day it pushed thru. However, there is Crius Ikon blue tooth adapter and cables (IKN605 and IKN607) that will allow it to be linked up to a phone, tablet or computer without the USB port and the included code (See attached pictures). The Ikon was original to this heli with very little use. $70.00 shipped.
I am asking ---------. for the above listed items plus Paypal fees. Shipping can be negotiated.
I have removed the servos (SOLD), but will include them with the sell. They were original to this heli with very little use as well. (See attached pictures.)
Thank you for looking. And please contact me with any questions, etc.
ID:	919831   Click image for larger version
ID:	919833   Click image for larger version
ID:	919835   Click image for larger version
ID:	919837   Click image for larger version
ID:	919841   Click image for larger version
ID:	919843   Click image for larger version
ID:	919845   Click image for larger version
ID:	919847   Click image for larger version
ID:	919851   Click image for larger version
ID:	919853   Click image for larger version
ID:	919855   Click image for larger version
ID:	919857   Click image for larger version
ID:	919861   Click image for larger version
ID:	919863   Click image for larger version
ID:	919865   Click image for larger version
ID:	919867   Click image for larger version
ID:	919871   Click image for larger version
ID:	919873   Click image for larger version
ID:	919875   Click image for larger version
ID:	919877   Click image for larger version
ID:	919881   Click image for larger version
ID:	919893   Click image for larger version
ID:	919895   Click image for larger version
ID:	919897   Click image for larger version
blkrvn1993 is offline        Reply With Quote Quick reply to this message
Old 06-01-2021, 11:56 PM   #2 (permalink)
Default Oxy
Still available 512-987-0700
Johnb326 is offline        Reply With Quote Quick reply to this message
Old 06-05-2021, 07:50 PM   #3 (permalink)
Default Oxy 3
Bump
Old 06-06-2021, 08:52 PM   #4 (permalink)
Have lowered to $300 shipped for everything. Will start parting out in the next few days if no offers.
Old 06-08-2021, 12:37 AM   #5 (permalink)
Default Oxy 3
Both NIP canopies and the NIP parts have been sold. Thanks to the buyers!!!
Old 06-10-2021, 06:01 PM   #6 (permalink)
Default Oxy 3
KST 215MG servos SOLD
Old 06-12-2021, 08:48 PM   #7 (permalink)
Default Items Still For Sale
Following are still for sale. Pics are shown in individual post for sale in "Electric Motors, ESC, etc", "Electronics Gyros" and 'Heli Parts" threads for the items.
Lynx Heli EOX 2214 (4100kV) V2 3S/4S brushless motor. Also, included are a 10T, 11T and 14T pinion for it. Asking $SOLD Shipped
Talon 35 $SOLD shipped.
Original Ikon. The USB port does not work. Because plugging into it one day it pushed thru. However, there is Crius Ikon blue tooth adapter and cables (IKN605 and IKN607) that will allow it to be linked up to a phone, tablet or computer without the USB port and the included code (See attached pictures). The Ikon was original to this heli with very little use. $70 shipped.
The following items are available as well. Asking $SOLD shipped for all of it.
Assembled
SP-OXY3-002 - OXY3 - Center Hub
SP-OXY3-005 - OXY3 - Main Grip, Set
SP-OXY3-008 - OXY3 - Swashplate
SP-OXY3-006 - OXY3 - DFC Arm, Set
Assembled
SP-OXY3-023 - OXY3 - Tail Rotor Assembly
SP-OXY3-030 - OXY3 - Tail Case Bearing Block Assembly
SP-OXY3-026 - OXY3 - Bell Crank Support
SP-OXY3-027 - OXY3 - Tail Pitch Slider
SP-OXY3-080 - OXY3 - Tail Shaft 15T
SP-OXY3-031 - OXY3 - Vertical Fin
SP-OXY3-032 - OXY3 - Tail Case Cover
SP-OXY3-033 - OXY3 - Tail Bell Crank
SP-OXY3-034 - OXY3 - Tensioner Tail Belt
SP-OXY3-010 - OXY3 - Upper Main Shaft Bearing Block
SP-OXY3-011 - OXY3 - Middle Main Shaft Bearing Block
SP-OXY3-012 - OXY3 - Lower Main Shaft Bearing Block
SP-OXY3-013 - OXY3 - Motor Mount
