Go Back   HeliFreak > R/C Electronics Support > JR and Spektrum Radios and Electronics > 2.4G JR Radios
2.4G JR Radios JR 2.4 Gigahertz Radios and Technology
View Poll Results: Did your X9303 have wire chafing inside upon inspection
Yes - My X9303 had a chafed wire 104 49.52%
No - My X9303 had NO chafing and was fine 106 50.48%
Voters: 210. You may not vote on this poll
Old 08-19-2008, 01:45 AM   #1 (permalink)
Default X9303 Internal Wire Chafing Issue IMPORTANT
Official fix from JR:
http://www.jrradios.com/Articles/Art...ArticleID=1822
I just spotted this on Flying Giants and RCU. I have no personal experience with the issue, but posted it from a safety standpoint (and I am a JR/Spektrum diehard) as I have not seen it here yet:
http://www.flyinggiants.com/forums/f...look-here.html
http://www.rcuniverse.com/forum/m_78..._1/key_/tm.htm
Last edited by WillJames; 08-20-2008 at 01:28 AM.. Reason: Added official fix from JR
Old 08-19-2008, 03:14 AM   #2 (permalink)
Registered User
Thanks for the heads-up. I will be checking my X9303 before I fly it again.
William James
Old 08-19-2008, 03:39 AM   #3 (permalink)
My DSX9 is OK (purchased in Oz) but the harness does look vulnerable fed through that small hole in the gimbal
John
Old 08-19-2008, 04:36 AM   #4 (permalink)
just checked mine.slight abrasion had started on the black wire,i flipped the strain relief around and now my wires are running down the side and to the left of the gimble.the way it is now the wires run parallel to the pinch point.
aristo is offline        Reply With Quote Quick reply to this message
Old 08-19-2008, 05:58 AM   #5 (permalink)
Thanks for the heads up. I'll be checking mine also.
Fury55 NIB Furion6 CGY750 fbl helicopter-Frenzy CGY750 fbl nitro-Frenzy fbl NOBAR90 and a clone450NOBAR
Burning Nitro and Electrons simultaneously
heli-cuzz is offline        Reply With Quote Quick reply to this message
Old 08-19-2008, 09:57 AM   #6 (permalink)
The Freak just saved me a bunch of money in Helicopter parts!!!!!!!!!!!!!!
Additional (and much larger) pictures here:
http://lerch.no-ip.com/Heli/X9303/
Now, the question is, what is the best approach to problem resolution. I seem to have caught mine before any substatial material was removed from the copper conductor. If I could, I would unsolder it and replace it, but that looks like a job and a half, as neither end is user friendly.
Not sure what the alternative is. (other than sending back to Horizon Hobby and joining a rehab facility)
Personally, I'd rather fix it myself. Towards that end, I think I will attempt to
  1. Remove and replace the chaffed cable
  2. While the cable is out, radius the plastic support
  3. Maybe radius the Voltage regulator that is the actual source of the problem.. I think there is plenty of material to grind away while not compromising the silicon inside.. (worse case I replace the voltage regulator with another from stock, which I actually have on hand. Maybe I'll go grind on a loose one first :o )
  4. What I'd LIKE to do is relocate the voltage regulator.. Simply moving it up into the vacant circuit board space about an inch would resolve all these problems.. (They, are going to make me warm up my home made re-work station, I can see this coming! )
James Lerch - Raptor 90, JR Vibe 500E*, Gaui 550E*, Xcell Razor* (*=On Loan)
http://lerch.no-ip.com/atm (My homebuilt telescope site)
http://lerch.no-ip.com/ChangFa_Gen (My 15KW generator project)
http://www.youtube.com/profile?user=JlerchTampa (my you-tube crash videos)
http://lerch.no-ip.com/Hat_Cam ("Hat Cam" for recording flights)
JimLerch is offline        Reply With Quote Quick reply to this message
Old 08-19-2008, 12:48 PM   #7 (permalink)
Registered User
That is funny Jim. Good thing you opened the back.
Thank you for the GOOD very clear photos so we can figure out if ours are doing the same. Popping open a radio is not something I normally do so I am kinda dreading it.
William James
Old 08-19-2008, 01:02 PM   #8 (permalink)
The Capi
Hmmm, my xp9303 is fine, wonder if it's x9303 related.
Old 08-19-2008, 01:12 PM   #9 (permalink)
HFG,
From what I have read on the RCU and FG threads, the problem appears to be solely with the X9303, due to an additional board on the 2.4 version to which is mounted a voltage regulator (the part that the wires actually rub against).
Will,
Thank you for making the thread "Sticky". I do not actually own one of these radios, but I know so many people who do and was very concerned with this from a safety aspect.
I firmly believe that these are excellent radios. This is a minor issue to correct that could cause major failures in the field if left undetected/corrected.
Old 08-19-2008, 03:50 PM   #10 (permalink)
Here is what mine looked like. Had it since december.
Representing:
AMain Hobbies, XNova Motors
Jason Bell is offline        Reply With Quote Quick reply to this message
Old 08-19-2008, 03:57 PM   #11 (permalink)
You're right on time Jason, thats almost one heli less in your fleet...
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 08-19-2008, 03:59 PM   #12 (permalink)
OK, I came up with a fix and implemented it. The problem isn't so much a "PINCH" but more of a wire rubbing against a near razor sharp corner of the LM2937 3.3vdc regulator. After sacrificing a spare LM2937 regulator which I found on an old, discarded disk drive back plane, I used this spare regulator as a test subject for surgery exploration.
What I found was there is significant amounts of "Extra" ceramic (or is it epoxy?) material out near the edges of the regulator.
To implement my fix, I took a dremel with a diamond covered drum bit and ground a fairly hefty bevel onto the offending side of the regulator. I don't suggest anyone else go this far, but mostly I wanted to demonstrate how far someone could go and not cause any damage.
Once I had the sharp edge of the chip beveled, I inspected the abraded wire and found only a few strands were scuffed, and none of the strands were actually broken. So, my quick and easy fix for this was a good dab of "Shoe Goo" on both the abraded wire and the beveled edge of the voltage regulator. The hope is the two bits of Shoe Goo will flow into one blob after quickly sealing the case.
I will need to be careful in the future, if I ever need to split the case again, but I can now prepare for my daily HELI fix, instead of fretting over an RMA back to Horizon Hobby.
Here's some pictures I took after beveling the chip (again, I don't suggest going this far, but I did for demonstration purposes). Also, I didn't blow the dust off for these pictures, as it made it difficult ot see how much I ground the chip down.
http://lerch.no-ip.com/Heli/X9303/Fix/
Here's a thumbnail from the page:
Old 08-19-2008, 04:20 PM   #13 (permalink)
WOW!!! I've only had mine since early April '08. If that wire broke, you would end up with full aileron deflection with no hope for recovery! ***
I wonder how much of an ass I should be when folks show up at the field with X9303s and haven't checked to see how bad they have it? Is this problem something that warrants the "You've haven't heard about this, or checked yours yet? Well lets do it RIGHT NOW!! Here's a screwdriver.. approach??
At a minimum, I should probably print out our pictures and put it up on the bulletin board at the field..
*** So, assume it did break, and somehow you started doing stationary aileron tumbles. As the disk heads towards level upright, could one go full rudder, throttle hold and maybe manage the collective to get it on the ground? (Just thinking out loud kinda..)
Old 08-19-2008, 04:26 PM   #14 (permalink)
Holy smokes, that is bad... thanks guys.. I will be checking mine tonight...
shamen222 is offline        Reply With Quote Quick reply to this message
Old 08-19-2008, 05:10 PM   #15 (permalink)
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 08-19-2008, 10:10 PM   #16 (permalink)
Yea Im REALLY glad I saw the thread and looked at mine, that would of been an expensive crash!
Representing:
Old 08-20-2008, 12:35 AM   #17 (permalink)
Thanks for the heads up! I will be checking mine.
Originally Posted by Pinecone View Post
I'm surprised that Horizon hasn't issued a recall!
Imagine if your wire broke and your heli/plank went down because if it. how long would you be like this trying to figure out what caused it. The last thing I would look at is my radio.
Thanks for making this a sticky!
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount.
T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount.
JR X9303.
bullaculla is offline        Reply With Quote Quick reply to this message
Old 08-20-2008, 12:50 AM   #18 (permalink)
this is funny i looked at jr's fix and it is exactly what i did to mine last night,i was going to post pics tonight lol
Old 08-20-2008, 12:53 AM   #19 (permalink)
thanks for the headsup. pinecone's link should be added to the top as well. i found the JR link by searching manually. would have been nice to have seen it earlier and saved some time.
gonna peek in my radio tomororw
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
cudaboy_71 is offline        Reply With Quote Quick reply to this message
Old 08-20-2008, 02:41 AM   #20 (permalink)
Default Mode 1 Seems OK
I just did the mod on my X9303. However, I doubt this is a problem with Mode 1 as is mine. The aileron wire goes under the throttle friction device and cannot get near the offending component. Still good to check.
Don
Don McCullough is offline        Reply With Quote Quick reply to this message
