Old 06-23-2021, 10:47 AM   #1 (permalink)
Default older V-bar
I want to install this v-bar
Not sure where the RPM wire goes I was thinking Sensor 2 as sensor 1 hase the gyro
Also where do I plug in the Telementery cable I'm using a Scorpion 06-80 amp ESC
Thanks for your help in advance
Charles
Charles
IAFF 2130
MAAC 55778L
rotorsport is offline        Reply With Quote Quick reply to this message
Old 06-23-2021, 11:37 AM   #2 (permalink)
You get no telemetry with those old vbars.
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 06-23-2021, 11:58 AM   #3 (permalink)
ok Thanks
Charles
IAFF 2130
MAAC 55778L
Old 06-23-2021, 02:35 PM   #4 (permalink)
a vlink neo is the way to go if your using vcontrol.
Old 06-23-2021, 07:27 PM   #5 (permalink)
Thanks I do have several neo's just wanted to see if I could use this one I think I will just put it in a Trex 450
Charles
IAFF 2130
MAAC 55778L
Old 06-23-2021, 09:50 PM   #6 (permalink)
The full size Blue Line can give you telemetry, plug goes into the ports on the side normally used for Spektrum sats. As these ports are one way ports you will not be able to change settings on Tribunus, YGE ESCs but will get the telemetry data as per normal.
Wiring is here https://www.vstabi.info/en/node/641 and yes the rpm goes into the sensor 2 port, WARNING this cannot handle any power in so only the black wire and signal from rpm wires on ESC must be plugged in.
VControl
Old hand at Planks
Peter
Vinger is online now        Reply With Quote Quick reply to this message
Old 06-23-2021, 10:33 PM   #7 (permalink)
If you are using a Vcontrol radio you will need a V-Link (like satellites but instead of Spectrum you are going to the V-Link which connects to the Vcontrol radio)
Is that your setup you have or something else?
Tek18x is offline        Reply With Quote Quick reply to this message
Old 06-24-2021, 08:31 AM   #8 (permalink)
Yes that is what I have, I have attached a picture in the first post.
Boy am I having fun Trying to program a Scorpion Tribunus 06-80A it will not connect, tried different USB cable, different diode cable.
This ESC is new within the last month, When I hook them up thru V-Bar controller with a NEo V-Link they work fine.
If I programing it with my Vbar touch Controller will ke same the settings when I move it over to the older V-Bar?
I really appreciate the help and advice.
Charles
Charles
IAFF 2130
MAAC 55778L
Old 06-24-2021, 09:25 AM   #9 (permalink)
Did you update the old vbar to version 6.0 for use with vcontrol?
Old 06-24-2021, 05:13 PM   #10 (permalink)
6.0.7 yes I just checked
Thanks I forgot about that
Charles
Charles
IAFF 2130
MAAC 55778L
Old 06-24-2021, 09:43 PM   #11 (permalink)
Charles
https://www.scorpionsystem.com/support/downloads/
Download the latest version of Sproto and the driver for the VLink2. Uninstall the old ones, restart PC install new and it should work. Always install driver WITHOUT the USB plugged in.
https://www.scorpionsystem.com/files...bunus06-80.pdf
You must use the Tribunus configurator in Sproto and not the Tribunus 2 one.
VControl
Old hand at Planks
Peter
Old 06-25-2021, 11:10 PM   #12 (permalink)
Ok thanks Iíll try that tomorrow
Charles
IAFF 2130
MAAC 55778L
