Go Back   HeliFreak > R/C Helicopter Support > OXY HELI > Oxy4
Like Tree2Likes
  • 1 Post By fiddle
  • 1 Post By jrman83
Old 06-24-2021, 07:33 PM   #1 (permalink)
Default Tail Servo Linkage Length
Is this correct?
Spektrum DX8 Gen2 / AccuRC 2
Oxy4 Max
iKnon2 BT / Scorpion HK-3014 / HW Plat Pro V4-60A / KST DS215MG v3 (x3) / KST X15-755X
CagedVR6 is offline        Reply With Quote Quick reply to this message
Old 06-25-2021, 05:18 AM   #2 (permalink)
It looks like it to me?
CagedVR6 likes this.
Vcontrol Touch, AccuRC & Heli-X Simulators
Oxy 5 MEG, 4 MAX, 2 (215)
SAB Goblin 500 Sport
XL Power Specter 700
Old 06-25-2021, 04:10 PM   #3 (permalink)
Just wanted to confirm thats what was meant in the document. Seems a bit far in (not much physical throw). Thank you.
Oxy4 Max
Old 06-26-2021, 05:39 AM   #4 (permalink)
That could be, but I'd follow what the manual says. There must be a reason. Oxy4max is pretty small ... maybe doesn't need much throw?
Old 06-26-2021, 02:03 PM   #5 (permalink)
Is your Oxy4 Max set up the same way?
Oxy4 Max
Old 06-27-2021, 06:18 AM   #6 (permalink)
I just checked and no it isn't... The manual I used does not contain that verbiage you showed (they update their manual all the time). I used the included servo arm (OXY0085) and put the bolt in the hole it showed. It is like 9.33mm or so....
It looks like the inner hole is 7.50 and the outer is 10.
The manual I used (REV 12) does not have a section: "How to correctly set the tail limit".
I would have done exactly as they said in the manual. It should be noted I am using a mini sized tail servo, not a micro...
Name:	Screen Shot 2021-06-27 at 7.13.55 AM.png
ID:	922665   Click image for larger version
Name:	Screen Shot 2021-06-27 at 7.16.02 AM.png
Old 06-27-2021, 09:09 AM   #7 (permalink)
Caged, are you using an Oxy 4 manual rather than an Oxy 4 Max?
Either way, what fiddle posted is correct.
XLP Specter V1, XLP 550, Oxy 4 Max, Oxy 2, OMP M1
Spirit GT Egodrift & XNova, YGE & Scorpion, FrSky Horus OpenTX
WTB XLP Wraith for cheap
xoexoe is online now        Reply With Quote Quick reply to this message
Old 06-28-2021, 08:21 PM   #8 (permalink)
I used what was posted here:
Now that I look at it, the Oxy4 is mentioned. Shoot. Should I be 10mm Out?
https://www.helifreak.com/showthread.php?t=800733
Oxy4 Max
Old 06-28-2021, 11:53 PM   #9 (permalink)
I think that's for Oxy 4, not Oxy 4 Max. Yes, use 10 mm.
https://www.lynxheli.com/product_inf...h9s1aoec5hl2e6
http://lynxheli.com//manuals/OXY4-MAX-MANUAL-REV12.PDF
Old 06-29-2021, 05:25 AM   #10 (permalink)
I say if it's working like you have it and no issues, leave as it is. No need to change it if it isn't causing problems.
Sent from my SM-G988U using Tapatalk
Old 06-29-2021, 02:39 PM   #11 (permalink)
jrman83: I am having some issues with the tail blowing out on hard collective punches. Gain is set correct
Oxy4 Max
Old 06-29-2021, 07:27 PM   #12 (permalink)
By all means put where the manual states to place on the servo horn if you're having issues and start there.
Not sure what you mean by gain is set correct. How did you set the gain?
xoexoe likes this.
-Ben
Old 06-30-2021, 06:50 AM   #13 (permalink)
Up till Tail Wag, backed off a hair.
Oxy4 Max
