Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 06-28-2021, 04:30 PM   #1 (permalink)
Default Balanced
If the rotor blades are unbalanced will the heli shake when spooling up?
Mikado Logo 550SE, Mikado Logo 400SE, Gaui X3, Align Trex 150x, Losi 8ight, Traxxas Rustler, DX8Gen2
mjlFlys is offline        Reply With Quote Quick reply to this message
Old 06-28-2021, 04:41 PM   #2 (permalink)
Yes, and when it’s flying!
If it smooths out, then it likely has more to do with with blade grip tightness and/or how straight the blades are to start.
If it’s smooth on spool-down then it’s likely the later…
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 / Kraken 580
JimJW is offline        Reply With Quote Quick reply to this message
Old 06-29-2021, 05:12 AM   #3 (permalink)
The KBDD ones I got a way out of balance
Would figure they’d be closer but they’re not
Usually they’re pretty close
I’ve gotten Align ones that are pretty close
These are 550 btw
Old 07-07-2021, 04:30 AM   #4 (permalink)
Do you think .2 grams would make it shake bad?
These are 550mm blades
2 tenths of a gram difference on 550mm blades and they shake pretty bad
It’s either that or a bearing or the frame where the bearing rides that’s broke
Old 07-15-2021, 02:53 PM   #5 (permalink)
it would not cause a bad shake, out of balance blades can cause the hellie to tip over on concreate.
If your shake is bad that maybe the thrust races are the wrong way round, normally this would show apart from a shake the blades would also come out of track when you add pitch.
Or it could be a bent spindle/shaft,
Have Fun
MattJenner is offline        Reply With Quote Quick reply to this message
Old 07-15-2021, 05:02 PM   #6 (permalink)
I actually got it figured out.
The tail pitch slider was loose and the tail blade was broken so it was causing the gyro to make the entire heli shake
I flys great now
