Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Like Tree1Likes
  • 1 Post By Thickfog
Old 06-29-2021, 07:34 PM   #1 (permalink)
Default Telemetry - Headspeed (HobbyWing Platinum PRO V4-60A)
Does the HobbyWing Platinum PRO V4-60A Telemetry show head speed or only motor RPM?
Oxy4 Max iKnon2 BT / Scorpion HK-3014 / HW Plat Pro V4-60A / KST DS215MG v3 (x3) / KST X15-755X
SAB Goblin 380 Buddy Xnova Lightning 2820 / YGE 65LVT / KST X12-508 (x3)
CagedVR6 is offline        Reply With Quote Quick reply to this message
Old 06-30-2021, 03:36 AM   #2 (permalink)
No esc gives headspeed telemetry.
You have to use the flybarless gov for that.
Sent from my moto g power using Tapatalk
CagedVR6 likes this.
Thickfog is offline        Reply With Quote Quick reply to this message
Old 06-30-2021, 07:48 AM   #3 (permalink)
Thank you for the info. I have the RPM Signal going to my iKon2 however I am using the HW Gov - Possible to get headspeed or do I have to use the iKon2 Gov?
Old 06-30-2021, 08:02 AM   #4 (permalink)
In order to get headspeed, it has to know the gear ratio. The programming box does not have a way to program that. I was playing with mine the other day and if you use the PC program connected to your HW box connected to the ESC I saw more governor options including gear ratio. I use the governor on my FBL so I didn't mess with it but take a look.
RustyChain is online now        Reply With Quote Quick reply to this message
Old 06-30-2021, 08:08 AM   #5 (permalink)
The Hobbywing v4 provides two different options for RPM telemetry.
The first is just simply pulses for each motor commutation. This is the wire that is normally plugged into the GOV port of the Ikon. To get RPM, the number of pulses per revolution needs to be entered into the FBL. Then converted from motor rpm to headspeed.
The second is the ESC reported digital RPM. This is a digital signal, from the wire plugged into the 4-5-6 port of the Ikon. Similarly the rpm is scaled from Motor rpm to headspeed (as Thickfog noted as well)
An ESC only really knows ‘eRPM’ or the number of commutations per minute. If you had a ‘2 pole’ motor then ‘eRPM’ would equal motor RPM. I believe that the digital RPM is eRPM (4-5-6 port data) and the GOV port pulses are obviously eRPM.
If the issue is that the reported RPM seems 10x too high, then check the transmitter RPM scale factor. On Spektrum, a factor of 10x is required as noted in the Ikon/Brain telemetry manual.
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 / Kraken 580
Old 06-30-2021, 08:50 AM   #6 (permalink)
You do not need to use the Ikon Governor to get headspeed telemetry.
I’m pretty sure this has already been covered in your other threads.
Old 06-30-2021, 09:20 AM   #7 (permalink)
and in the ikon2 manual.. under telemetry..
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 06-30-2021, 09:41 AM   #8 (permalink)
The head speed conversion is calculated and handled by your Ikon. Follow the instructions for setting up the gearing values/telemetery for your Ikon.
Tony
Synergy 516, Gaui R-5 Speed, Cypher Vtol Jet, Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
