Like Tree1Likes
Old 07-18-2021, 11:34 PM   #1 (permalink)
Default Blue Bird servos?
So this looks pretty good compared to the KST rudder servos.
https://flightcomp.com/collections/s...nal-protection
People on flying Giants seem to like them
https://www.flyinggiants.com/forums/...ad.php?t=68332
Anyone around here have experiences to share? I like the idea of a servo with over and under voltage protection and stall protection and the specs are very good too. I've used their micro servos in a couple small helis (the BMS-207 turned out to be a great 450 size servo) and the internal build quality was good (solder joints on internal; leads glued down to protect from vibration) and since then I've been wanting to give their full size servos a try.
Old 07-19-2021, 01:42 AM   #2 (permalink)
It's the same range of servos that BK are re-branding as their own, so I guess that says something positive?
BK use the BLS-30A internals for their cyclic servo and the narrow band BLS-18AN for their tail servo.
The top CNC case on the BK looks a bit different but actually that's standard BlueBird too, they take from the BlueBird helical gear servo range (eg BLS-H51)
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | SoXos Strike 7 | Henseleit TDR, TDSF & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Smoggie is online now        Reply With Quote Quick reply to this message
Old 07-19-2021, 03:41 AM   #3 (permalink)
Their latest servos i believe are good. But their old products werent very reliable, concluded this from research as i was planning on ordering some they had on sale but never went ahead with it.
eXo, HD502, OXY, Protos
Spartan VX1n/e, Frsky RX, RT Blades MKS/BK, Hobbywing
Danker16 is offline        Reply With Quote Quick reply to this message
Old 07-19-2021, 04:36 AM   #4 (permalink)
So BK has switched away form Servoking and is using Blue Bird now?
Blue Bird has plastic shelled versions of the BLS30A and BLS17A (plastic top and bottom with an aluminum center) but I haven't been able to find a source to actually buy them. They are listed on their products page though.
https://www.blue-bird-model.com/products_detail/424.htm
https://www.blue-bird-model.com/products_detail/425.htm
If they follow the pricing for Blue Bird's previous servos then they should be $20-$25 less than the all aluminum versions.
Old 07-19-2021, 04:52 AM   #5 (permalink)
They're one of the servo manufacturers I'm actively keeping an eye on, I don't own any of their servos yet, but they're on my shortlist for brands I'm planning to purchase next time I need more.
As mentioned above, the fact they've taken over from ServoKing as the new OEM for BK Hobbies is a tick in the box for me. And they're stocked by hyperflight.co.uk here in the UK with some decent reviews, including comments that they're being used in DLG world championship events. The signs I've seen are that some very experienced, and very picky pilots have been flying the brand for a good few years at least on both the heli and the plane side.
I'm also a big fan of the fact that they're one of the few manufacturers of micro servos that are rated for HV operation and can run straight from a 2S lipo. They have the BMS-127WV range at 11.3g rated to 8.4V, and they even have a 4.5g HV servo with the BMS-101HV.
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
myxiplx is online now        Reply With Quote Quick reply to this message
Old 07-19-2021, 05:00 AM   #6 (permalink)
I like that they use a 25T spline instead of some custom micro spline like most servos of that size.
I used the BLS-127WV in my Oxy2 and they were excellent, so then when I built an X360 I found that my go-to KSTs had increased in price by quite a bit. so I used the 127WV's bigger brother the BMS-207WV which also turned out to be a great servo with better specs and lower price than the KST 215/315.
Aloft Hobbies has them here in the US for $22 and $28.
https://alofthobbies.com/blue-bird-bms-127wv.html
https://alofthobbies.com/blue-bird-b...e-voltage.html
I went ahead and ordered the BLS-17A from Flightcomp. The 3DIGI doesn't support higher than 333hz on the tail servo so there is no need to spend extra on the narrowband version if the FBL doesn't support 560hz operation anyway.
Old 07-19-2021, 06:53 AM   #7 (permalink)
Originally Posted by Atomic Skull View Post
So BK has switched away form ServoKing and is using Blue Bird now?
Yes.
BK-9001-HV = BlueBird BLS-30A
BK-9005HV = Bluebird BLS-18AN
I had to snigger a little when I saw BK's claim of 'Unique CNC Design' when in reality the CNC design is from the standard Bluebird parts bin, as used on their BLS-H51 range of servos.
But the spec looks excellent.
Old 07-19-2021, 07:54 AM   #8 (permalink)
I had a chance to talk to BK for a bit at the Fall Heli Mowdown last year. Asking when his servos would be back in stock, he said the manufacturer of the motors in his servos went out of business and he was looking for a new supplier. They were servoking servos for sure. But I believe the motors, boards specs etc were different. I may be wrong though.
0xy4 Max Goblin Kraken 580 Goblin Kraken 700 NX10 Ikon2
Ravmano7 is offline        Reply With Quote Quick reply to this message
Old 07-19-2021, 12:24 PM   #9 (permalink)
Talking
So now they are called BlueK servos...lol
Ironically enough, my oldest helicopter that I fly, an original Logo 500 (converted to flybarless) has Bluebird servos. This helicopter and servos are from around 2005-2006. From a personal persepctive, 15 year old Bluebird servos, and have been reliable.
charles is offline        Reply With Quote Quick reply to this message
Old 07-19-2021, 04:11 PM   #10 (permalink)
The boards were for sure the same as Servo King. The motors could be different though. This jives with the Blue Bird / BK servos, they are slightly faster and have slightly more torque than the Blue Bird equivalent which could be explained if they used a different motor. The difference is very slight .031 sec for the BK at 8.4v vs .035 sec for the Blue Bird and less than 1kg-cm torque difference.
The speed on the 17A / 18A is slower than an Align DS825 (.002 sec 12kg-cm, which is an amazing rudder servo in my experience). But I have a theory than a slightly slower but much stronger rudder servo might have the advantage in hard stops.
I'm not really happy with the KST MS1035 I have on my A7 (.003 sec 12kg-cm). Tuning the left /right hard stops was a pain and still isn't quite as good as my other helis that have an Align DS825 on the tail where the stops are perfect. I'll see how the Blue Bird 17A compares.
Old 07-19-2021, 06:56 PM   #11 (permalink)
From what I have read this top (the one used in helical gear servos and magnetic sensor servos) has a larger top bearing, necessary due to the side load placed on the upper bearing from the helical output gear.
Old 07-20-2021, 02:06 AM   #12 (permalink)
https://www.helifreak.com/8256437-post74.html
dreamteam is offline        Reply With Quote Quick reply to this message
Old 07-23-2021, 07:00 PM   #13 (permalink)
Received the 17A today.
It is ridiculously strong for a rudder servo, I can not budge the arm at all while it is powered. It is also very fast, full sweep happens in the blink of an eye. It seems faster than the MS1035 even though the specs say it is slightly slower.
Gear pins have brass bushings pressed into the aluminum and the pins are also thicker than on a KST servo. They are also removable not pressed in.
The bell gear is small diameter compared to most other servos I have seen.
The motor is held in my a small pair of countersink screws under the midgear can can be easily removed (in theory) by taking out those screws. In practice the pot wires are too short to allow the motor and PCB to come completely out of the shell.
The solder connections to the pot legs are covered in a blob of transparent epoxy to protect against vibration.
The pot leads are 22 AWG and soldered to through holes in the board. Clearly the pot is installed first and then the wires are soldered to the PCB.
The pot is held in by a screw that is hard but not impossible to access, you'd need a slightly angled screwdriver to do this. Then you could pull out the whole assembly.
There is no goop on the board side of the pot leads nor on the main servo lead solder joints, but I doubt they will cause problems with the through holes and relatively heavy gauge wires, I can't see them flapping around inside the case. If you wanted to apply your own you could slide the motor halfway out and apply it with a nozzle. I might do that with an IC heli.
The servo gets very warm in operation, normal tester left/right sweep only gets warm, if you really work it fast with a radio and receiver then it starts getting very hot. I will keep an eye on temp but I suspect it won't be bad in normal operation.
I have it installed and I'll do a test flight tomorrow.
msallua likes this.
Old 07-24-2021, 06:53 PM   #14 (permalink)
So with default settings it's pretty good. The stops are pretty decent but will need some tuning to get it perfect. I think I started with the gain too low it seems this servo wants more tail gain than the KST MS1035.
Also this servo rotates backwards compared to most and will need to be inverted in the setup.
The servo does get pretty warm during normal operation but it's a rudder servo that's strong enough to be used as a cyclic on a 700 so maybe that's an unavoidable result of packing so much torque and speed into such a small package.
Old 07-29-2021, 06:29 PM   #15 (permalink)
I am flying a XL Power 550 with the BlueBird BMS A920 mini servos on the cyclic, they perform great.
They are not exactly low cost price wise though, a fair bit more torque and a small amount slower than the MKS H9767 that I have in my 6s Goblin 580. Cannot tell any difference flying between the servos in flight, they both work great.
Blue Bird BMS-A920 MINI Servo. This servo features the following:
Coreless design
Full Aluminum Case
All Metal Gears
High Voltage
Futaba Spline
Specs
@7.4V - Torque: 13.7kg-cm/190.3oz-in Speed: 0.09 sec / 60degrees
Rotor-Tech Blades
Old 07-29-2021, 07:12 PM   #16 (permalink)
I remember blue bird servos back 20 years ago. They where cheap junk. Would not trust them then, see no reason to trust them now. That's me but spend YOUR money how you see fit.
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 07-29-2021, 10:41 PM   #17 (permalink)
If they are junk then BK servos are also junk, and I don't think Bert would sell junk servos.
Old 07-30-2021, 03:51 AM   #18 (permalink)
And of course companies, technology, products and engineering knowledge don't change at all in 20 years...
The reports from the last several years all look excellent, and the specs are good too. Next paycheck I'm picking up four BlueBird servos for a plane to start trying them out myself.
Sent from my SM-G970F using Tapatalk
Old 07-30-2021, 06:42 AM   #19 (permalink)
All about power of a brand name.
Blue Bird = crap
BK = great
Even though the physical product is identical.... Go figure
Old 07-30-2021, 03:52 PM   #20 (permalink)
Back then Blue Bird was targeting the same market as Corona and GWS, of course they were cheap they were $5 servos. They were some of the better servos in that market segment though.
