Go Back   HeliFreak > R/C Helicopters > Speed Helicopters
Speed Helicopters Speed Helicopters. Any brand as long as it goes FASSSSSSSSSTTTTTT!
Like Tree2Likes
  • 1 Post By jhamel
  • 1 Post By jhamel
Old 10-31-2017, 12:48 PM   #1 (permalink)
Default SAB Comet: motor options, head speed, and other considerations for a speed newbie?
I am considering purchasing a Comet as my introduction to speed helis. I have never flown speed before, so I am expecting a steep learning curve. I plan to build it as a speed heli. I already have a Kontronik Kosmik 200A ESC as well as brand new 7S LiPos for it. I am trying to figure out what motor to go with it. I am also trying to determine what head speed I should aim for as it will determine the motor pinion I will need. Also, should I use the stock SAB 720/105 blades or should I use other blades, i.e. Rail 96 tail blades?
Name:	Comet motors.jpg
14S Tron 7/Protos 700X Evo/Kraken; 7S Kraken 580/Logo 550SX V2; 6S Buddy 380 KSE
VBC Touch & Neo Vlinks, YGE "T" ESCs; AGM Deep Cycle Batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Field Representative
Old 11-01-2017, 12:23 AM   #2 (permalink)
Not knowing any better, I went with the Xnova 50XX 535kv Speed motor. I figured if it has "Speed" in the name it should be good enough for speed flying, and if it is Xnova brand it is likely to be good quality. I also ordered the 23T pinion. I'll let the Kontronik governor determine the optimal governed head speed which I anticipate will be around 2500rpm at 80% throttle and 2350 at 75% throttle.
The question remains regarding the blades. Should I stick with the stock SAB 105mm tail blades or should I go with shorter Rail 96mm blades?
Old 11-01-2017, 07:02 AM   #3 (permalink)
CHC Benefactor
I'd start with rpm 2,300 or below and pitch 13 degrees and work my way up to 16 degrees max from there, although not familiar with recommendations or limitations of the Comet. 96mm Rails on tail good idea.
Old 11-02-2017, 10:16 AM   #4 (permalink)
OK. I'll start with the stock 21T pinion and take it from there. I'll install the stock SAB 720mm main blades, but use the shorter Rail 96mm tail blades. I'll start with a max collective pitch of +13. Thank you.
Old 11-06-2017, 07:35 AM   #5 (permalink)
Try not to crash it like your R5 maiden...
TheKingPhisher is offline        Reply With Quote Quick reply to this message
Old 11-06-2017, 11:47 AM   #6 (permalink)
I know. I still have PTSD from that experience.
TheKingPhisher likes this.
Old 11-07-2017, 06:35 AM   #7 (permalink)
Great comment.
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 11-07-2017, 07:52 AM   #8 (permalink)
For completion, the issue with the R5 was a bad tail servo.
Old 11-07-2017, 11:41 AM   #9 (permalink)
CHC Benefactor
Good luck with the maiden
Old 11-07-2017, 12:51 PM   #10 (permalink)
Thanks. I'll need it.
Old 11-07-2017, 02:18 PM   #11 (permalink)
Coming to OHB? There is going to be a speed event on Thursday, and there will be many of the speed gurus there to chat with.
Matt
Goblins - Mini Comet, 380, 500, 700
BK Servos, Spartan vx1e FBL units, Switch Blades
Jeti DS-16
TORCHS member, AMA 64878, Citizen 690
Mattinfla is offline        Reply With Quote Quick reply to this message
Old 11-07-2017, 02:34 PM   #12 (permalink)
I wish. It will be very challenging to make it to OHB this year.
Old 05-23-2021, 07:24 PM   #13 (permalink)
Default Update
curious how everything went? How did the heli end up flying for you? What advice would you pass onto a person doing their first speed build.
EGODRIFT // ManiaX
Xpert RC USA // KBDD
www.HeliDirect.com
Edge67 is offline        Reply With Quote Quick reply to this message
Old 05-23-2021, 09:15 PM   #14 (permalink)
It flew fine, but it tipped over on landing. Caused a lot of damage, and I never bothered rebuilding it.
Old 06-03-2021, 08:56 PM   #15 (permalink)
Thing tips easy huh?
HeliBeachBum is offline        Reply With Quote Quick reply to this message
Old 06-22-2021, 06:45 PM   #16 (permalink)
What did you end up doing with it would you like to sale it? Would t mind having spares
Helis are addictive and make me poor.
thepainter is offline        Reply With Quote Quick reply to this message
Old 06-22-2021, 07:47 PM   #17 (permalink)
I sold it about 3 years ago. I don't miss it.
Old 08-12-2021, 09:19 AM   #18 (permalink)
Wait...how did it "tip"?
Were you doing an auto or something? On grass or concrete?
Old 08-12-2021, 10:34 AM   #19 (permalink)
Landed on grass. As the blades spooled down (without power), the heli started shaking and tipped over.
Old 08-12-2021, 05:03 PM   #20 (permalink)
Oh yeah those little skids are not good on grass. I got the retractable for my kit, but I'm thinking I should be near pavement when taking off and landing or at least hard dirt.
