Old 08-14-2021, 03:28 PM   #1 (permalink)
Default AR7210BX firmware update issue
Hi.
I wonder if someone could help here. I recently sold a AR7210BX to someone who is having an issue withe firmware update. I haven't done any updates before or registered the product prior to selling it.
The buyer is trying to update and gets the following messages.
When connecting the device - it says "Firmware Update is Available".
Then it goes into update mode - Displays device details like serial # etc.
Then it says "At the moment there is no firmware available for this device"
Images for each of the above are attached.
Then it goes back to the original screen and the whole thing repeats. I am checking with the new owner if they have registered the device on their account - I believe this is a necessity? In the meantime, please if someone has any ideas as to what is going on here.
Thanks in advance!!
ID:	928089   Click image for larger version
ID:	928091   Click image for larger version
$washplate is offline        Reply With Quote Quick reply to this message
Old 08-14-2021, 03:53 PM   #2 (permalink)
I’ve experienced the same thing when the serial number of a particular Microbeast device isn't properly listed in the BeastX database (for whatever reason). A short email sent to info @ beastx.com explaining the problem along with the device serial number is all that is needed to get the problem corrected. Usually you'll receive a response within 24 hours (outside of a weekend).
John L.
Gyropilot is offline        Reply With Quote Quick reply to this message
Old 08-14-2021, 03:56 PM   #3 (permalink)
Wow thanks John! That was quick reply!!
Much appreciated. I will post back.
Old 08-16-2021, 08:32 PM   #4 (permalink)
So I emailed BeastX and they did update their database and now StudioX recognizes the unit. Thanks John.
But now there is a different problem in that the Firmware flash is stuck at 0% for more than 10 mins and after a few attempts - Any thoughts on how to get past this please.
Thanks in advance.
Old 08-16-2021, 10:03 PM   #5 (permalink)
Sorry I’ve never encountered that so not sure I can help.
It’s a long shot, but have you tried doing a factory reset? See the BeastX wiki here:
https://wiki.beastx.com/index.php/Ma...actoryReset/en
Also, before you try anything else, be sure and read the section titled “When the update fails” on this wiki page:
https://wiki.beastx.com/index.php/St...mwareUpdate/en
Please keep us posted.
John L.
Old 08-16-2021, 10:09 PM   #6 (permalink)
Thanks John - We've also dropped an email to BeastX. I'll update as we learn more!!
Old 08-17-2021, 07:09 PM   #7 (permalink)
So, BeastX came back and advised to switch off the radio during the firmware update process and it worked. (Updated to 4.2 from 4.1.5)
Now the next problem is that it doesn't allow the user to use the software for programming the FBL - It goes straight to Firmware update window and is stuck there. We've asked BeastX for further help.
Is there anything we could try while they look into the issue.
Thanks!!
Old 08-17-2021, 07:42 PM   #8 (permalink)
Wow what a struggle this is becoming!
The latest version firmware for the AR7210BX should be 5.1.3 so it's possible that StudioX is strongly "encouraging" an update again before it can work correctly.
You may also want to verify that the user is using the very latest version of StudioX.
John L.
Old 08-17-2021, 07:49 PM   #9 (permalink)
Thanks again John! Still trying to persevere!
The StudioX version is 3.6.2 - Looks like this is the latest. The software the user is trying to upload is the latest "Fee free" software. I am not familiar with how this works but I am told that the older firmware becomes free to download use whereas the newer ones are for a fee?
Old 08-17-2021, 08:24 PM   #10 (permalink)
Ah yes… it's been so many years ago that I'd forgotten it was a paid firmware upgrade to go from 4.x to 5.x on a AR7210BX.
I'm at a loss as to why StudioX wouldn’t now work correctly with that particular AR7210BX. Hopefully it’s something simple like operator error or the turning off transmitter thing.
John L.
Old 08-18-2021, 01:41 PM   #11 (permalink)
I use StudioX version 3.3.6 for my AR7210BX firmware updates(to v4.2 only) - no problems at all.
To access the on screen programming of my AR7210BX's I use StudioX version 2.2.4 which also works a treat.
So I have two versions of StudioX installed on my laptop; each for a different purpose and all good if you do not want to go beyond Firmware version 4.2.
I think issues arose with the introduction of v5 firmware and also StudioXm which I have never wanted and the reason why I have stayed with the earlier StudioX versions.
AR7210BX firmware version 4.2 gives me all I need and I have stayed with it - straight forward and hassle free!
Cyclone7 is offline        Reply With Quote Quick reply to this message
Old 08-18-2021, 01:53 PM   #12 (permalink)
Thanks Cyclone!! This most likely explains the issues!!
Now, the question is how to obtain that version of StudioX. I can't seem to find it on the BeastX website or Google it.
Thanks!
