Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Like Tree5Likes
  • 1 Post By dogbreath
  • 2 Post By Xrayted
  • 1 Post By Xrayted
  • 1 Post By Voyager
Old 08-15-2021, 07:34 AM   #1 (permalink)
Default Geolink, altitude sensing
Sooo, for sensing altitude, does the Geolink just use a pressure sensor ?
Is the GPS only for horizontal position for geofence, rth etc. or does GPS sense altitude as well?
2009 TDR, TDSF, Kasama Dune and Faifa, Minicopter Triabolo 700, RMJ Raptor gasser, Beam E4 and Avantgarde, JR E8 leggero, Suzi Laos, Shape S8, 'TDRex' 800, Rave 450, Trex 500.
trillian is offline        Reply With Quote Quick reply to this message
Old 08-17-2021, 02:11 PM   #2 (permalink)
if i am correctly understanding the information in the manual => all embedded sensors like pressure, gyro, accelerometer, compass, etc are used to improve the precision of the GPS.
Ciao
Michael
minicopters & Logos, YGE, Egodrift, Spirit 2/RS/GT/GTR, Jeti DS-12/Spirit Ed.
Rabid121 is online now        Reply With Quote Quick reply to this message
Old 08-17-2021, 02:56 PM   #3 (permalink)
Yeah, that's very vague though, and that's literally the only mention of the pressure sensor. So it doesn't really tell us anything. I suppose the ultimate question really is: Which is better when talking strictly about altitude sensing, the GT or the Geolink.
Ciao
Michael
Old 08-18-2021, 07:24 AM   #4 (permalink)
Great question. And when using both GT & Geolink, does the better one over-ride the other one?
Dan
trillian likes this.
Synergy 696; Synergy 516; Synergy 516 stretched to 557/96; Jeti DS-16v1 / DS-12. Planks.
No-Team; Non-Rep, no-skill. Free advice worth every penny.
dogbreath is offline        Reply With Quote Quick reply to this message
Old 08-18-2021, 08:45 AM   #5 (permalink)
There is a barometer for detecting altitude in the Geolink as well Trillian unless I am misunderstanding you? That's how any hard deck works as GPS is not a good way to determine altitude and has a large error margin of up to 15M and this error gets worse with altitude. That makes GPS alone completely useless for our needs as far as altitude detection goes
With the Geolink you have the barometer to trigger "rescue" and then the GPS working in unison to hold the model at that location. With the GT you will get the altitude trigger, but then you are on your own after that without the GPS no differently than standard rescue.
I do seem to recall mention of a better barometer logic being used in the GT due to faster processor, etc so that is something to consider vs the barometer in the Geolink though.
The biggest challenge for this tech on a heli is the constant changes in pressure that are created and how quickly/accurately the unit can detect these changes. This is why some may need to test at first with a relatively high 10M/30F deck in order to rescue the model before it hits the ground depending on flying style and possible speed/trajectory when breaching the deck
Even a small delay/error in readings for a 700 sized model coming in fast at a steep angle could result in the model breaching deeply through the set limits before rescue triggers. Easy upright sport flying on the other hand may be just fine with a much lower deck setting, even with some error so its going to be different for each pilot style
trillian and torpicaltrail like this.
Tony
Synergy 516, Gaui R-5 Speed, Cypher Vtol Jet, Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is online now        Reply With Quote Quick reply to this message
Old 08-18-2021, 10:05 AM   #6 (permalink)
Yes, we know it has a barometer, and also GPS. But as yet, no definitive info on whether altitude is only determined by the barometer, and how altitude sensing accuracy compares between the Geolink and the new GT.
Soooooo, for example, if the Geolink relies solely on the barometer for altitude... and IF you only want the hard deck feature.... then it would seem logical that you could mount it anywhere and just forget about GPS, which would actually make it much more versatile (although - with redundant components - except possibly the accelerometer data for when the heli is approaching the altitude limit at speed, etc).
Originally Posted by Xrayted View Post
There is a barometer for detecting altitude in the Geolink as well Trilliuan unless I am misunderstanding you? That's how any hard deck works as GPS is not a good way to determine altitude and has a large error margin of up to 15M and this error gets worse with altitude. That's makes GPS alone completely useless for our needs as far as altitude detection goes
Old 08-18-2021, 10:17 AM   #7 (permalink)
Thanks, I see what you are asking now. That's a good question for Tomas I guess as he will be the only one to know precisely what logic is being used between the two setups, and how much if any of the GPS is used for the hard deck alone functionality vs what happens after the rescue occurs.
Tony
Old 08-22-2021, 12:51 PM   #8 (permalink)
I am interested in this as well.
Really only want a reliable hard deck.
I already have a standard unit with GeoLink in one Heli but would like to know if I am better with a GeoLink/GT or just the GT standalone for my next Heli conversion?
Voyager is offline        Reply With Quote Quick reply to this message
