Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Like Tree10Likes
Old 09-21-2021, 11:16 PM   #21 (permalink)
Originally Posted by Thickfog View Post
Goblin 380 at 2200 rpm. Certainly not mushy. Not underpowered. Little bit of collective control is all.
And easy to fly. Far easier than a 120sr or any of that garbage money sink crap.
Sent from my moto g power using Tapatalk
Hmmm...never saw the tail blow either at 2200 head speed as someone mentioned.I'm going to assume the OP doesn't fly anywhere as good as you Thickfog,so his chances of blowing out the tail is very minimal especially if he's just hovering around and doing simple circuits.
I'm sorry,but i don't mean to sound like 90% of the people yapping like a "Parrot"
Mikado Logo 700-VTX-MKS-XNova-Vbar Neo
Kraken 700-VTX-Xpert-XNova-Vbar Neo
Align Trex 700L Dominator-VTX-Xpert-XNova- Vbar
MSH Protos 700X- Cyclones-Xnova-Xpert-VBar Neo
flipboy is online now        Reply With Quote Quick reply to this message
Old 09-22-2021, 11:13 AM   #22 (permalink)
Thanks Flipboy. You were correct just hovering and flying circles with the 380
And seen no reason to run this at 3,000 RPM’s in case of a blade strike
All of my practice is with a CMPX and a 230 blade. But when you see this 380 on the shelf you just get tempted to try it out, even if it’s only hovering
John
flipboy likes this.
Raceboy is online now        Reply With Quote Quick reply to this message
Old 10-15-2021, 10:32 AM   #23 (permalink)
IMHO, head speed has nothing to do with the “twichyness” when using an FBL heli. The FBL unit will feed in as much pitch as it takes to attain the preset roll/pitch rate. I say this because I learned to fly in a trex 450 flybarred. In that heli, anything below 2600 rpm will make it almost uncontrolable. I then bought another trex and went FBL on it, using a k-bar FBL unit. It was so stable it felt almost as cheating in comparison. From 2400 to 3000+ rpm, the roll rate feels almost the same. In the flybar one, even a 100 rpm bump is noticeable. Since I am relatively inexperienced, my goal is to go with the lowest rpm I can, in order to increase flight time. The limiting factor, as I see it, is always the tail. If you go too low in headspeed, the tail will not have enough authority to hold the tail when you feed in a healthy amount of collective. Experiment: how low can you go with the tail still solid, then add 100 rpm to that, just to be safe. Then work on the cyclic response using the agility setting on the fbl and dual rates and expo on the tx. For the record, for learning, I used 50% D/R and about 15-20% expo. That should give you a docile and stable heli to practice hovering manoeuvres. Another advice I give is: forget the +/- 13 degrees pitch curve with 0 at center stick. For hovering practice, I recommend using a F3C pitch curve with hover pitch (5 degrees) at midstick, and 0 degrees at low stick. It will give a much better resolution and avoid going up and down like a maniac. Some will argue that you should not do this, because it will be hard to progress to 0 pitch at midstick later on. I think not. You should be able to master both configurations, starting with the easiest one first. I am by no means an authority on this, just sharing my experience. I thaught myself how to fly an heli and this is how I made it. One (light) crash so far in over a year I have been on this, flying almost every day. Take care.
Oliveirax is offline        Reply With Quote Quick reply to this message
