Go Back   HeliFreak > R/C Helicopters > Helicopter Safety
Helicopter Safety R/C Helicopter Safety
Old 08-30-2008, 11:17 AM   #21 (permalink)
Team Taco VP
I sent an email to Horizon telling the Bob is starting all sorts of crap over their radios .
Only kidding.
Eeeek.... I was about to slap you silly and break off your hold switch
Bob
Old 08-30-2008, 10:39 PM   #22 (permalink)
Bob
Do you think that is the modification we need to do to the radio to fix the obvious problem?
--T-Rex 450 V2 (mostly) 430XL - CC35, GY401 W/S9650, HS65MG, AR7000e, 325 Carbons
--T-Rex 500 all metal head, GY401 W/S9254, HS5245MG, AR7000, 425 carbons
-- DX7, Hyperion Duo, flight leader case
rockjock3 is offline        Reply With Quote Quick reply to this message
Old 09-01-2008, 11:49 PM   #23 (permalink)
Default Because it overrides throttle stick position
I think the explanation is quite simple (or maybe I'm quite simple... ). We call it "throttle hold" because the customary way to use it is to program it to low throttle (zero for electric, idle for nitro). However, the important consideration is that it can be programmed to any value and when it is engaged, it overrides the throttle stick position. It could potentially be programmed to a value well above zero throttle. The rationale is that the radio requires you to have both low throttle stick and any programmable mode that can override the low stick position disabled before it will establish a connection with the receiver.
Have laser, will travel.
cbdane is offline        Reply With Quote Quick reply to this message
Old 09-02-2008, 05:36 AM   #24 (permalink)
That's a good point. I wonder if you reprogrammed your TH curve to be 0 at low throttle if the warning would not occur with the switch on. I'll bet it wouldn't.
saltyzoo is offline        Reply With Quote Quick reply to this message
Old 09-02-2008, 06:19 AM   #25 (permalink)
Maybe because you can decide hold position by yourself. Default is -5.0%, but you can easily set it to 50.0%.
theWulong is offline        Reply With Quote Quick reply to this message
Old 09-02-2008, 11:47 AM   #26 (permalink)
Still gives a warning. It's just saying, "Hey, I'm not going to start up with a function engaged that overrides the low throttle stick position." Or in other words, "I'm not going to decide whether the override setting on the throttle hold function is safe."
What? Your transmitter doesn't talk to you? Ohhh... That must also explain the voices in my head.
Old 09-02-2008, 11:48 AM   #27 (permalink)
'Zactly!
Old 09-13-2008, 06:24 AM   #28 (permalink)
OTOH, the Tx can be turned on with the throttle stick at full throttle.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 09-15-2008, 03:04 PM   #29 (permalink)
right, if I re set up all of my t-curves such that they are all 100% across the board, the tx will still start with throttle hold "off". Not much of a safety...
This heli stuff is a pretty deep Rabbit hole, you just have to decide how deep you are willing to go...
fogger is offline        Reply With Quote Quick reply to this message
Old 09-20-2008, 05:27 PM   #30 (permalink)
Three emails to HH and still no response from them. Strange, because I have always gotten speedy responses from them.
Old 01-07-2009, 05:44 PM   #31 (permalink)
I like the alarm on the hold.
When I turn the TX on, I listen for the alarm and clear it by a quick flip of the switch back and forth. This way, I know for sure that the switch is in the correct position for hold before I begin powering on my heli. (I also use the low throttle stick in norm for extra protection)
Squirrlybird is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 08:11 AM   #32 (permalink)
It would be nice if they had a warning when th hold was off
kumar2494 is offline        Reply With Quote Quick reply to this message
Old 05-08-2012, 03:16 PM   #33 (permalink)
Yes it's stupid and reversed. Forcing pilots to turn *off* throttle hold is very strange when you look at it from a safety perspective.
From a software developers perspective it makes sense: the TX should beep when any mixes or switches are 'active'. It's time to change the requirements...
compie2 is offline        Reply With Quote Quick reply to this message
