Like Tree1Likes
Old 10-31-2009, 08:03 AM   #201 (permalink)
The fan should not turn if you are spinning the clutch bell by hand as the clutch is not engaged. Since the magnets are on the fan you won't read the sensor. You can use a starter shaft to turn the engine and fan via the starter coupling.
joediamond is offline        Reply With Quote Quick reply to this message
Old 10-31-2009, 08:50 AM   #202 (permalink)
MulitGov Pro flew awesome!! No issues whatsoever and holds the headspeed exactly where it says it is!! I had a buddy tach me and it was dead on!!
MaSt0RaS - the sensor only picks up one magnet. The other one is for balance purposes only. That is why you place one with north side up and the other north side down (or vice versa).
Team me
Twrecks600 is offline        Reply With Quote Quick reply to this message
Old 10-31-2009, 10:26 AM   #203 (permalink)
lol my friend i am not a newbie... i know that....
My heli is the velocity that have the magnet on the clutch bell....!
what i am asking is if the sensor test works when you spin fast the clutch bell.....
Mine doesnt work... if i turn it slowly its ok...!
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 10-31-2009, 10:36 AM   #204 (permalink)
The Capi
The LCD is unlikely able to update fast enough to see the test when you spin the bell quick enough.
Old 10-31-2009, 10:46 AM   #205 (permalink)
that is what i want to hear... also the nearest the sensor is the best right???
but it must touch the sensor the magnet....!
Old 10-31-2009, 02:57 PM   #206 (permalink)
Also something else my Epa are 115 115 i cannot have it near 100 rhe horns are 90o i dont know why.. with my OS was a lot near 100
Is this a problem?
Old 11-01-2009, 11:32 AM   #207 (permalink)
Hi everyone
I have a new issu with my MGP .
Just unmount it from my raptor to my trex gasser for be able to know exactly the noise 1500RPM do
But, once i mount it, the blinking is fast... I saw i had enable the mixture control, so, i disable it . Then, the blinking is slow but the gaz servo doesn't move. When i saw the pulse meter , nothing move . I have try several servo, all slots (for the gaz servo and for the channel to MGP link, cannot get the pulse work , always 0 ms ...
When i use the test point (high and low), the servo move btw
Do you have an idea ?? I unbox it and nothing smell burn or burn at view.... But don't work ;(
i notice too that i can plug all links upside down, and the screen start too, weird
tyio is offline        Reply With Quote Quick reply to this message
Old 11-19-2009, 04:01 PM   #208 (permalink)
ok i see
tomrinkevich is offline        Reply With Quote Quick reply to this message
Old 01-16-2010, 03:32 PM   #209 (permalink)
bonjour !
Je n'arrive pas a régler les trois positions du manche .
Merci par avance
abdocaliber is offline        Reply With Quote Quick reply to this message
Old 01-22-2010, 01:11 PM   #210 (permalink)
Hi Guys,
Have a quick question,
is it ok to power up my switchglo pro from the MGP Aux channel?
Cheers
- Michalis |OXY Heli|XNova Motors|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 01-22-2010, 02:32 PM   #211 (permalink)
Team Taco VP
It's all shared over the same power buss so I don't see why not.
Bob
Old 02-17-2010, 08:56 PM   #212 (permalink)
Default feild test
any follow up on the multi gov tunning up the gov.
MARKR2689 is offline        Reply With Quote Quick reply to this message
Old 02-17-2010, 08:59 PM   #213 (permalink)
i had to make changes to mine gov to get good power.
Old 02-19-2010, 03:17 AM   #214 (permalink)
Mark, what kind of changes have you done?
I think my engine is tuned OK but I can't seem to be able to get rid of some overspeeding when unloading and some lack of power in tic tocs. With the gov off the power seems to be better...
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote Quick reply to this message
Old 02-19-2010, 10:29 PM   #215 (permalink)
i turn up 3d agres up to 35 going to go up with feed foward next .
Old 02-23-2010, 03:55 AM   #216 (permalink)
a question in my mind
will this work on radikal g20?
asif222 is offline        Reply With Quote Quick reply to this message
Old 03-08-2010, 11:52 AM   #217 (permalink)
Quick question, I probably already know the answer. Tried a search and didn't come up with anything.
I know your normal throttle curve is supposed to be 0-100. My question is can I change this to something more reasonable to get a proper headspeed? like 0-40-80?
I'm thinking the 0-100 is only for setup(programming the high/low point) and I can do whatever I want in normal after this is setup. Is this correct?
Thanks.
DustinB is offline        Reply With Quote Quick reply to this message
Old 03-08-2010, 12:22 PM   #218 (permalink)
Team Taco VP
Yes of course you can up your normal curve. Most people do not have the gov on in normal mode but I do and use it in normal My normal curve to make sure the heli gets up and on the gov at 1800 is 0, 60, 90. If the gov fails in normal I should have a OK head speed in normal with this curve. Of course this curve is for my 700 and 600. Other helis your milage may vary. Whats best to do is turn gov off and hover in normal and adjust that middle number to the head speed you want. This way you know the curve is OK should the gov fail for any reason.
Bob
Old 04-12-2010, 11:00 AM   #219 (permalink)
Im using JR 9ch but im using 7ch Rx , im using aux2 for my flybarless and gear for gyro !
any way that i can put this gov on?
magickop1995 is offline        Reply With Quote Quick reply to this message
Old 04-12-2010, 11:55 AM   #220 (permalink)
Team Taco VP
The Multigov can be used without a channel controlling RPM.... BUT.... You only get one RPM for all flight modes.
Bob
