Like Tree1Likes
Old 12-30-2010, 10:45 AM   #261 (permalink)
Default MultiGov Pro
Will this work with an RDS8000 from Airtronics?
cstoutr is offline        Reply With Quote Quick reply to this message
Old 12-30-2010, 02:28 PM   #262 (permalink)
Team Taco VP
I don't know the RDS8000 but I do not see why not. Should work with any radio.
Bob
Old 12-30-2010, 09:27 PM   #263 (permalink)
Default Multigov pro
The RDS8000 doesn't have the switch assign function. I have been told that it will not work for 3 flight modes. Do I really need 3 flight modes though. I can have N and idle 2 and no idle1.
Old 12-31-2010, 10:38 AM   #264 (permalink)
Team Taco VP
I would ask in the Airtronics forum. I just do not know the RDS8000 radio at all.
Bob
Old 04-15-2011, 09:40 PM   #265 (permalink)
Originally Posted by joediamond View Post
I have a MultiGov Pro installed on my Trex 600N. I have been flying it with the governor enabled in all modes with the RPM set to 1700, 1850 and 1950 for normal, idle1 and idle2. Throttle curves were set per the manual to 0-50-100 for normal and 100-80-100 for idle1 and idle2. With this setup the governor worked perfectly with a nice smooth transition between flight modes.
Recently, I switched to having the governor off in normal and on in idle1 and idle2. I have the normal throttle curve adjusted to maintain 1700 RPM with the governor off, the idle1 and idle2 curves are still set to 100-80-100 per the MultiGov manual.
The problem is now when I switch from normal to idle 1 the headspeed increases rapidly and overspeeds badly until the governor gets it under control. I can fix it by adjusting the idle1 throttle curve to more closely match the normal curve but now it's no longer the 100-80-100 that Aerospire recommends.
Any suggestions on how to avoid the overspeed when switching from a non-governed mode to a governed one? All the hardware checks out and the MulitGov is picking up the backplate sensor properly.
For now I have gone back to using the governor in all three flight modes.
I have this exact problem.
MultiGov NON-PRO V2.0
Stratus YS90.
I'm running:
Normal: rpm set to below 500.... OFF
Throttle curve at hover is around 30.... maybe this the problem...LowThrotPcent Set to 35%
Idleup1: 1750 FULL
Curve: 100-75-100
Idleup2: 1900 FULL
Curve: 100-75-100
For some reason it speeds up way higher.
If I switch back to normal and then back to idleup1, it correctly engages. Maybe because at that point my throttle stick might higher and closer to the next range.
Rotormast V-22 Osprey, 2 450 Clones, BL P-51, Micro P51, Stryker, 2 Vapors,
hoot is offline        Reply With Quote Quick reply to this message
Old 04-15-2011, 10:04 PM   #266 (permalink)
OK this was a good thinking exercise for me.
There is a parameter in the advanced menu labeled "Startup Speed"
"Lower values will increase the startup time (a
slower startup). Higher values will make the
governor try to reach the target speed faster when
it becomes active (faster startup). Startup period
expires approximately 5 seconds after being
active."
Old 04-15-2011, 11:08 PM   #267 (permalink)
I noticed the Finless video says use 100-80-100 throttle curve for stunt mode.
Apparently there is a lot of differences between the MG and the MGP, at least in the manuals.
The MG (non-pro) manual has separate curves for FULL gov and Overspeed Limiter (OVSP)
FULL = 100-60-100
OVSP = 100-80-100
The MGPro only recommends the one curve for stunt. 100-80-100
The problem is this.... nothing to do with any of the above.
I want a normal mode NO GOV.
It doesn't work. You do get the NO GOV but when you switch to idleup1 and the gov engages, it way overshoots.
Anybody have a solution?
How does Multigov receive stick position info?
Throttle curve is not providing stick position in normal. My normal throttle curve is kinda flat around 25-30% up until 50% since you don't really need throttle until the pitch starts to kick in.
Old 04-16-2011, 08:09 PM   #268 (permalink)
Got my answer here. Gov time delay from off to on
http://rc.runryder.com/helicopter/t6.../?p=5292186#RR
Old 04-17-2011, 11:38 PM   #269 (permalink)
Anyone can help me with the programming with the 14MZ? I am noob to 14MZ, too good a radio for me..
Kasama Srimok 90: JR8917HV all round | YS91SR | Hatori 946 | Spartan Quark | BLS251
http://nitro-magic.blogspot.com
TmMugen is offline        Reply With Quote Quick reply to this message
Old 04-18-2011, 05:47 AM   #270 (permalink)
Do you have your flight modes set up... normal, idleup1 and idleup2?
If so, that's pretty much all you need to do on the radio side. The MG does need signal from the channel on your radio that outputs governor. Make sure you have gov enabled in all three flight modes and they have large rate changes. Make normal gov rate 0, idleup1 rate 50 and idleup2 100.
Multigov sees the modes and automatically switches through the speeds.
Go into Multigov setup. When you see the first speed on the display, flip the stunt switch to idleup1 and the speed will change to speed2, at idleup2 it will go to speed3.
Make your speed changes in Multigov and switch your radio to each speed using the stunt switch.
Old 05-06-2011, 10:08 AM   #271 (permalink)
Hi, I have the complete set of the old MultiGov (not Pro) and I'm planing to upgrade to pro and my question is whether I need the whole set or if I can replace only the unit, makes it cheaper for me. Anyone knows?
mgorgis is offline        Reply With Quote Quick reply to this message
Old 05-06-2011, 10:17 AM   #272 (permalink)
Default Multigov
I would think you could just replace the control unit. You will also need the programmer to talk to it. All of the sensors should work the same.
Old 05-06-2011, 11:22 AM   #273 (permalink)
I have the programmer from the non pro, temp sensor I don't have since the non pro doesn't have mixture control, will the old programmer work?
Old 05-06-2011, 12:28 PM   #274 (permalink)
Team Taco VP
I honestly do not know if the old programmer will work on the Pro. Email Aerospire as they are really good at responding.
Bob
Old 05-06-2011, 12:35 PM   #275 (permalink)
Hi, is there any pics/vid on how and where the mixture control servo mounted?
Old 05-06-2011, 03:50 PM   #276 (permalink)
Team Taco VP
On what heli?
Bob
Old 05-06-2011, 05:07 PM   #277 (permalink)
I've got a Trex 600N. I've watched your vids Bob about the multigov pro, great vids but don't know how and where to mount the servo. Regarding the programmer, I think I must buy the new one as the old one doesn't support the mixture controller. I'll contact aerospire about it.
Old 05-06-2011, 05:12 PM   #278 (permalink)
Team Taco VP
Align makes a bracket for the 700 for a mini servo to control the carb. I do not know if they make one for the 600. Have a look at my Carb Smart videos and I show how to mount the servo on the 700. Might help give you ideas how to do it on the 600.
Bob
Old 05-06-2011, 05:16 PM   #279 (permalink)
After watching your setup vids of the multigov pro I'm going to buy one and not a carbsmart as I had planed earlier. I'll download the carbsmart vid right the way :-)
Old 05-06-2011, 06:49 PM   #280 (permalink)
Just got an answer from aerospire, the non-pro LCD will work with the pro unit! :-) thought I share this info.
