Like Tree1Likes
Old 04-12-2009, 08:46 AM   #81 (permalink)
Originally Posted by simusphere View Post
I watched the multigov videos and Bob states that during the governor test its supposed to turn on at around 20% throttle in normal mode. I have a linear throttle curve and no matter what I do it still won't turn on until the stick is ABOVE 50% throttle. What affects the turn on point of the governor that can adjust this back down where it is supposed to be?
This may be a silly question, but did you set the high and idle throttle points correctly?
Check the LowThrotPcent value in the configuration. The default is 30% but may have gotten changed.
HeliFreak Support
Graupner MZ-32
Old 04-12-2009, 11:21 AM   #82 (permalink)
I did it just like in the video for the hi and low throttle points. The throttle goes to high and low properly during the test but on the next screen when testing the governor is where the problem is. It won't turn on until my collective stick is at 55%! I did check the vaules are default for the setting you mention. I guess I could reset everything back to factory defaults and try again. If it still doesn't work after that, I have no idea what's going on.
simusphere is offline        Reply With Quote Quick reply to this message
Old 04-12-2009, 11:46 AM   #83 (permalink)
Team Taco VP
What are your throttle channel end points? If you messed with them and got them far away from 100% it might mess with how MG sees 30%
Bob
Old 04-12-2009, 06:18 PM   #84 (permalink)
My throttle endpoints are at 100:100. I just reset the multigov back to factory defaults and set it up again per the video's and I still get the exact same result. You should know I am using an Airtronics Stylus radio but I doubt that has anything to do with it.
Wait!!! I just checked my throttle curves again and some how my curve for the mid point was down to 26%. Sorry about the confusion, my mistake. The multigov is working just fine now.
Old 04-13-2009, 07:01 PM   #85 (permalink)
Default problem with mgp
I am having some problems with the headspeed dropping around mid stick. I got home after flying and did a bench test on the mgp. When I go into idle 1 or 2 and move the collective up and down the the throttle servo is raising and lowering the throttle like it is flying the throttle curve and not the target headspeed. Will someone please do this bench test and see what they they get. It looks like to me the throttle servo would stay at full throttle because the gov would be trying to acheive the target headspeed no matter where the collective would be.
I am running a futaba 7c 2.4 could some please post some of there settings in the gove menu. My mix is on in the gov menu and I have verified that the gov is kicking on above 20% throttle.
kickybanks is offline        Reply With Quote Quick reply to this message
Old 04-13-2009, 08:20 PM   #86 (permalink)
Team Taco VP
YOU CANNOT test throttle response on the bench PERIOD! What you are seeing on the bench is your V throttle curve!
Lets clear up some things. The MPG will NOT turn on and take over throttle control until:
1) The throttle stick is above 20-30%
2) The gov is reading an RPM close to a percent SET RPM
3) The gov is reading a RPM signal from the RX (optional if your using that).
If when using the gov your RPM is dropping too low coming out of 0 pitch maneuvers, raise your bottom end V curve OR use the programmer to change that low setting.
Bob
Old 04-13-2009, 09:28 PM   #87 (permalink)
If the gov is working in flight how does raising the v curve help the low headspeed around midstick. The gov would be keeping the target headspeed so how do i raise the headspeed around midstick. I'm in idle up, running 2050 rpm and it only happens at mid stick. I get a front to back bobble when hovering after a quick negative to positive pitch change. the bobble stays there until I pitch pump it again, it's relly weird. I had the gv-1 before this and when You put it in idle up on the bench it would stay full throttle like it was trying to get to the target head speed no matter where the collect was. The throttle would not change through the whole motion from neg to pos pitch.
Old 04-13-2009, 09:42 PM   #88 (permalink)
will someone with the 7c 2.4 please post there settings for the gov and do this bench test and see if they get the same results. turn on electronics and switch to idle up and go from neg pitch to pos pitch and see if the throttle servo moves like the v curve is being used .
Old 04-14-2009, 01:14 AM   #89 (permalink)
Team Taco VP
Huh?
Kicky.... READ the GV-1 manual. It also says the gov will not take over until it reads a RPM from the magnet. So whatever you THINK you saw on the bench was just your curves!
NO gov I have ever used (Revmax, MPG, Curtis ATG, TJ Pro, GV-1, etc) will show you ANYTHING on the bench........ Trust me on this.....
Now can I ask... Are you trying to use a GV1 sensor on the MPG? If so... WONT WORK PERIOD!.... The GV1 sensor is very different than any other gov sensor AND is not compatible!
Bob
Old 04-14-2009, 10:33 AM   #90 (permalink)
Default Im using a backplate sensor
Is there anything I can do to stop losing the head speed around mid stick. I'm in idleup and arounjd midstick I get a horrible front to back bobble, any suggestions ?
Old 04-14-2009, 02:15 PM   #91 (permalink)
Team Taco VP
Increase your middle point on the V curve....
Bob
Old 04-20-2009, 08:05 AM   #92 (permalink)
If you are running gov mode with the MultiGov, the V curve should be set to 100 - 80 - 100.
The MultiGov reads the throttle signal change to lead the need for an actual throttle change. So if is sees the throttle signal go from 85 to 90, it knows that the pitch increased, so it can start to open the throttle BEFORE the RPM decays.
And waht Bob was saying, I think, is if your headspeed bogs too much the gov will see too big of a difference between the actual headspeed and desired headspeed, and will take itself out of the loop. But with a higher mid point, the throttle curve will open the throttle, get the headspeed up to where the Gov takes over again.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 04-22-2009, 09:04 PM   #93 (permalink)
Bob,
I set my throttle curves on my Futaba 10C to all 100% and 80% in the middle, is that ok? Or do i need to drop it little by little from each point?
Thanks.
Shockwave 3K is offline        Reply With Quote Quick reply to this message
Old 04-23-2009, 07:09 AM   #94 (permalink)
As long as the points in between are disabled or inhibitied, you are fine.
On my X9303 (7 point curves) I run 100 - Inh - Inh - 80 - Inh - Inh - 100. Or more easily 100- 80- 100.
Terry
Old 04-24-2009, 10:48 AM   #95 (permalink)
I can't inhibit curves on my radio.
Old 04-24-2009, 11:25 AM   #96 (permalink)
Team Taco VP
What radio?
Bob
Old 04-24-2009, 06:49 PM   #97 (permalink)
10C
Old 04-24-2009, 08:32 PM   #98 (permalink)
Team Taco VP
Yes you can turn off points in your curve! See my 10C videos. I show how.
Bob
Old 04-25-2009, 06:02 PM   #99 (permalink)
Ok great thanks.
Note in general: LISTEN TO FINLESS!! I messed with the gain settings and ended up having to go through the trouble of changing the settings back.
Old 04-27-2009, 07:19 AM   #100 (permalink)
Bob i have a spare MGP sitting on the bench and have the AR7100R in my T-rex 700.
What would you do? Use the MGP and dissable the revlimit mode on the reciver? or keep it the way it is? Im running the Y.S.
I have a MGP in my T-Rex 600NSP and it is awsome!
Cheers Bob!
Phillip A. Al-Redha is offline        Reply With Quote Quick reply to this message
