Like Tree1Likes
Old 10-17-2008, 10:03 PM   #101 (permalink)
i maidened my 500 today with the G770
it's rock solid
i don't know why people say it's hard to set up
also
ir spins super fast on 100% DR
brian94066 is offline        Reply With Quote Quick reply to this message
Old 10-18-2008, 01:28 AM   #102 (permalink)
If you really want to see fast lower the gain a few clicks.....
ping is offline        Reply With Quote Quick reply to this message
Old 10-18-2008, 08:38 AM   #103 (permalink)
Since no answer, I went ahead to shift out by one hole which is roughly 14mm instead of the previous 11mm.
Tail slide reverse flight and piro flights but tail holds rock solid.
Originally Posted by hotdogbun View Post
Hi Fin, I need some advice.
I am using JR G770T with Futaba 9257 on my Protos.
The servo ball link set at 11mm from centre of horn, I am not getting full throw on the tail slider even with Gyro's servo throw at maximum. Reason for setting to 11mm is because if I use another further hole, it seems to be quite far out. With all this, I am causing the link rod to rub against the rod guide.
Strang thing is, my gyro is holding rock solid even at fast tail slides and reverse flights.
My question is, can i use a further hole (3rd from centre) on the servo horn? With this hole I do not need to max our my Gyro's servo throw and the rod will not rub the guide.
Many thanks.
hotdogbun is offline        Reply With Quote Quick reply to this message
Old 10-18-2008, 09:33 PM   #104 (permalink)
IT looks like Im one of the only futaba Tx' user that wants to try this gyro.
I got some advice from F1 Rocket over on RC Groups. Here is what my E-620 Raptor is working with. I havent tried anything else as so far I have no drift, no wag, nothing but head holding just like I was hoping for.
My End Points are maxed out at 140/140
Gain is 25% Futaba gain scale is 100---0---100 so no math required, everything right of 0 is HH gain
Dual Rates are set at 50%
Expo is set at -40
The ball is mounte 11.5mm from the center of the servo shaft(8900)
So far I have found no reason to change anything at all. Im just sport flying..since that is all Im capable of.
Jimmy
Jamesppp is offline        Reply With Quote Quick reply to this message
Old 10-20-2008, 02:26 PM   #105 (permalink)
I am setting up the 770 on my protos. So far, I am 13.5 mm out on the servo arm. when the arm is 90 deg the travel on the tail is right at the middle. servo on the boom clamp with the Futaba gyro tape and no metal plate in between
End point set at +/- 150, dual rate at 85%, expo at 50.
Gain initially set at 40% on HH. The tail was OK while hovering except at the end when I sat it down on the grass, it was wagging very badly.
So I lower than gain to around 26 on HH
I hover it for a flight and the head drift to the left very noticeably but no more wagging.
Should I...
a) play with the gain more
b) remount the gyro with zeal tape
c) change the servo horn to 10.5 mm out and max out the servo travel on the gyro
d) rerun the gyro wire so that it is not next to any other servo wires
e) use metal plate?
Or combination of the above?
houstonrevo is offline        Reply With Quote Quick reply to this message
Old 10-20-2008, 02:36 PM   #106 (permalink)
Should I...
e) use metal plate?
I have solved the bounce back problem on the right piro, I used aligns metal giro plate with two lots of self adhesive pads and a Velcro strap, the tail is real solid now and the stops on the tails are crisp fast with no bounce back , it now feels like a different gyro , now its awesome gyro when you know how it works.
ps
The gain on the 770t is vary sensitive try the metal gyro plate and the foam pads and also lightly strap the giro down with Velcro
Keep trying with the gain only down by 1 at a time 770t is vary sensitive
darrenwootton is offline        Reply With Quote Quick reply to this message
Old 10-20-2008, 03:00 PM   #107 (permalink)
Hello Guys
I have also a JR770 on mine trex 600.This is the baddest gyro I've ever had.I tried realy realy everything.I have a Futaba FF9.
In the manuel they say (works only with Jr equippment but Iam trying to believe this.I have some strange boucne effects when during hard stops during side ways maneuvers.First I had the gyro in front on the gyro plate now its on the back,but without any change.
My gain is 9% if I go a little hyer its chaking realy bad.
If someone has a good setup with a ff9,tell me please.
PRACTISE MAKES PERFECT
davy is offline        Reply With Quote Quick reply to this message
Old 10-20-2008, 07:10 PM   #108 (permalink)
I was running my 770 on a Raptor 50 with a JR nes-8700G servo and could not set the gain anywhere without the tail wagging. Of course the lower the gain the slower the wag, at high gain I got violent wagging. I decided to check the speed of the current servo to find out it was fast at .09 sec. Then I checked the speed of the new JR DS8900G servo to find out it was almost twice as fast at .05 sec. I bought one, switched it out and the tail is now solid. OMG what a relief. Anyone experiencing wag problems with the 770 I would encourage them to check the speed of the servo they are using against the 8900 or the 3500 depending on the size of your heli.
Chopper Patrol
JR-XG14, JR Forza 700, Warp 360
CHOPPER PATROL is offline        Reply With Quote Quick reply to this message
Old 10-20-2008, 08:14 PM   #109 (permalink)
I had bad wag problems on my 600n with the 770. Came to find out it was caused by one of the tail supports being very slightly loose. So to tighten things up some more I wrapped the boom with electrical tape, flipped the top of the boom clamp upside down, and super glued the boom support screws into the clamp. No wag now.
Just something to check out...
Jeff
500cf, cchv85, ccbec, 5452mg, 7703d, 3400g, ....>400 flights > 5 crashes make an offer!
600N Sport, os50hyper, mp5sb, 8717, thunder tiger 600mm, solid g, 8900g, 7100r
Compass K3D, os50hyper, outrage, 8717, 8900, spartan, 8900, radix, 7100r
rupps5 is offline        Reply With Quote Quick reply to this message
Old 10-21-2008, 10:31 AM   #110 (permalink)
Originally Posted by davy View Post
Hello Guys
Try these settings on your Futaba Radio:
Expo is set at -40
The ball is mounte 11.5mm from the center of the servo shaft(8900 servo)
Jimmy
Old 10-22-2008, 06:39 AM   #111 (permalink)
Any update on when we will see the set-up vid on this gyro Bob?
All I can say is "WOW!!"
billbill242000 is offline        Reply With Quote Quick reply to this message
Old 10-22-2008, 02:22 PM   #112 (permalink)
Team Taco VP
It's coming....
Bob
Old 10-22-2008, 06:32 PM   #113 (permalink)
I am confused about the JR G770T EXPO setting on my Protos. Seems like mine is totally different from all, but all my reverse flight and hard tail slides are ok with the tail holding very very well. I "inhibit" my Rudder EXPO, meaing it is ZERO ... anyone having the same as me?
Tail servo - Futaba 9257 (14mm)
Gyro Gain - 61%
Rudder DR - 48%
Rudder EXP - 0%
EPA - 150/150
Tks
Last edited by hotdogbun; 10-22-2008 at 06:33 PM.. Reason: Forgot to mention it is Rudder EXPO
Old 10-22-2008, 06:33 PM   #114 (permalink)
how sensitive is it?
if i inhibit my RUDD expo, the tail gets REALLY REALLY sensitive
Old 10-22-2008, 06:34 PM   #115 (permalink)
Cool!!
Old 10-22-2008, 06:36 PM   #116 (permalink)
Team Taco VP
Well I haven't tried it yet as I am still building the Atom it will go on. But I assume that JR wants you to add some expo as the tail sensitivity around center stick it too quick based on what some people may be use to running other gyros. I can tell you for sure the Logictech 6100 HAD to have expo in the 50% or more as the tail was just WAY too sensitive at center stick. So again I assume this maybe true for this gyro as well but I will see when I get there. Seems you are saying it may not really be that sensitive with no expo... I will try it for sure.
Bob
Old 10-22-2008, 06:39 PM   #117 (permalink)
Yeah, JR says that 40% expo is like no expo on most gyros. So 50% expo is like 10% on a Futaba gyro.
It seems that many have expo built into the gyro. Sounds like the LogicTech 6100 is the same.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 10-22-2008, 08:31 PM   #118 (permalink)
The first time I used this gyro I did not have any expo and d/r set at 100% with the trex 500. First impression was "holy $hit this tail is fast". I now have it at expo 30% and d/r at 60% for the 500 with k&b blades. For the 600n I have it at expo 25% and d/r at 60% with the shorter k&b blades.
Jeff
Old 10-23-2008, 06:05 AM   #119 (permalink)
I did have wack during hover but once I reduce throttle curve to 78% the wack stops. Any value higher hunting comes back.
I am running a Guai 550 stock motor with 15T pinion on 2x3S2250mAh30C.
Maybe at higher rpm the tail becomes too sensitive..so maybe some expo will help. Do keep us updated. Though I am quite happy with my headspeed atm. Motor bog still bearable to do piro flips.
Old 10-23-2008, 07:49 PM   #120 (permalink)
It sounds as if your gain is too high. At higher headspeeds, the tail becomes more powerful and you can't run the gyro gain as high as you can at a lower headspeed.
The ESC could also be the culprit, if the RPM's aren't steady, the result could be a tail wag. If you're running in gov. mode, you could try adjusting your governor gain if that seems to be the problem.
John Barta
Michigan Whirlybirds Heli Club
http://www.michiganwhirlybirds.com
j bomb is offline        Reply With Quote Quick reply to this message
Tags
101, dual rates, expo, g770, gyro, gyro setup, jr g770, video, videos
