Difference between Align 425F and 425D?? - HeliFreak
Old 09-30-2008, 12:45 AM   #1 (permalink)
Default Difference between Align 425F and 425D??
Does anybody know the difference between the Align 425F and 425D blades? They look the same and all of the specifications listed on Align's website are the same. The price is different and they took the time to make different boxes so I assume something has to be different
http://www.align.com.tw/shop/product...oducts_id=2394
http://www.align.com.tw/shop/product...oducts_id=2283
More helis than brains
Funky is offline        Reply With Quote Quick reply to this message
Old 09-30-2008, 12:48 AM   #2 (permalink)
Looking at both pictures I noticed one set has one rod running through it and the other has two rods. What that means, I don't know.
Miniature Aircraft Furion 6 (12s)
Compass 7HV Ultimate
Team Heliproz
ambravo is offline        Reply With Quote Quick reply to this message
Old 09-30-2008, 01:25 AM   #3 (permalink)
one is more 3D oriented?
brian94066 is offline        Reply With Quote Quick reply to this message
Old 09-30-2008, 05:28 AM   #4 (permalink)
1st, the rods are actualy weights,
however, altough there are two weights, the overall weight seems to be the same (120 grams).
so my guessing is that the diff, is the CG of the blade.
i.e. the CG is more to the ends of the blades.
ohh, and another thing - the F are blue .
now, have look at https://www.helifreak.com/showthread.php?t=87675
lavi is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 06:52 AM   #5 (permalink)
i need to buy some blades...
People that have tried both: can you recommend if you like more the F or the D ?
mapas is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 07:59 AM   #6 (permalink)
go for the D it's a good all round blade and will handle 3d well
Alex
MY BLOG Stop by say hi :-)
500 ESP: Ely Q Comp: "Kasama'd Trex 600N:
lex7919 is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 05:26 PM   #7 (permalink)
the F's are big chunky power-hungry blades and will slow your cyclic down a lot.
They will be very good for auto's though. Go for the D's
Daniel
DX7 - Mode 1
TREX 450 PRO!! - GP750 & DS520 - HS65's - AR6100 - Scorpion -8, Align speedy
legine is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 05:44 PM   #8 (permalink)
Isn't one set foam core and the other wood?
Edit: nevermind.
Only tried and crashed on the D's.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 05:57 PM   #9 (permalink)
Edit: nevermind.
It seems that BOTH have the same weight...
However one has two metal rods (weights) the other has one...
Old 06-16-2009, 06:20 PM   #10 (permalink)
ok, so, what are the performance differences between these two blades?
RyuuChi is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 06:37 PM   #11 (permalink)
This is what i am asking
Old 06-16-2009, 06:52 PM   #12 (permalink)
Here's some search results for these two blades together in this T-Rex 500 forum. I have only used the Fs so I can't compare them to the Ds. One of these days I'll have to give them a try.
https://www.helifreak.com/search.php?searchid=3650988
T-Rex 500GF, Compass Knight 3D,Raptor E700, Rave 450
Newest member of the fleet: Synergy N7
Futaba 14SG
airpup86C is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 08:06 PM   #13 (permalink)
I would try these. The set I ordered were great,, perfect balance no tape required plus they are on sale.
http://www.helidirect.com/align-425m...069-p-7069.hdx
AMA # 927862
Trex 500 FBL esp Kontronik Jive 80LV / Scorpion 1600kv - JR 3517mg cyclic - BeastX / Futaba BLS 257- Compass Tracx FBL head
JR9303tx / AR7600rx
wall is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 08:28 PM   #14 (permalink)
A few months ago I was experimenting with a flybarless 500 and I wanted the heaviest, most tip weighted blades I could find. I compared the weights and CG of both theses blades with the other align blade (in the link right above) and two other brands of 500 blades. The blue 425F align blades were the most tip weighted of any I had and weighed slightly more than the others too. At least that was the case with the ones I had. The blue 'F' blade also seemed slightly more flexible than the align blade (in the link right above) that I'd been flying.
I still haven't flown the 425D's but the CG is more inward toward the root than the 'F' blade.
lakespinner2 is offline        Reply With Quote Quick reply to this message
Old 07-17-2009, 07:06 PM   #15 (permalink)
so, maybe the d's are more 3d oriented and can flip faster cuz the weight is closer to the center of the rotating mass, kinda similiar in to the theory of adding flybar weights on a 450?
Old 07-18-2009, 05:05 AM   #16 (permalink)
What I find really odd here is that the manufacturer clearly had these blades designed by someone who knew what they were doing. At least, I hope so! Then instead of giving the buyer these details, they leave us to speculate with guesses such as wood core, foam core, 3D, not 3D, heavier, lighter, etc, etc. Strange way of doing business. So my question is - has anyone got manufacturer's answers on the differences? Align are terrible at responding to mails.
paul530a is offline        Reply With Quote Quick reply to this message
Old 07-18-2009, 08:05 AM   #17 (permalink)
i have flown the d blades and thay have a lot of pop
the d blades have more cyclic punch i believe
i use the old stockalign blades
great punch,i did have radix on my 500 but tacoed them bad hihihi.for the trx500 the radix blades have nearly no punch but are very stablie and track great
hawkins221 is offline        Reply With Quote Quick reply to this message
Old 07-20-2009, 10:20 PM   #18 (permalink)
I fly both. They are both awesome as for 3-d etc..or just flying the pattern. Buy whatever is on sale, or whichever one looks better to you.
kevinbourland is offline        Reply With Quote Quick reply to this message
Old 07-20-2009, 11:51 PM   #19 (permalink)
F blades didn't track D blades did. F where louder to.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 07-21-2009, 12:24 AM   #20 (permalink)
You know, that just recently happened to me. I've had 3 sets of F blades. The first pair balanced and tracked perfect. The set I bought some months later required a little tape to balance, and I could never get them to track perfectly, but close enough to fly. The last set, I could not get them to track no matter what I did. I wasted a good flying day messing with them, and then put on a set of the regular Align white carbons and went flying. I think I'm done with the 425Fs.
They did fart nice and loud though.
Al
Futaba 14SG
Insurance
Human Verification
