Register | FAQ | PM | Events | Groups | Blogs | Calendar |
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum |
05-03-2014, 10:03 PM | #1 (permalink) |
2nd KDE Motor 700XF Failure
Since the first KDE motor failure, I have my second failure today and within a month. After a power cut in flight in which I manage to auto down with only a landing gear failure on my G770, the motor was seized. As I tried to open up the motor, this is what was discovered.
Broken pieces of motor was found caught in the motor thus seizing the motor mid flight. My previous 700xf motor had the same failure but the broken pieces were smaller. This is absolutely unacceptable, I bought the motor with high hopes I am getting a good product. This motor was on 12s coupled to a cc edge 160HV and I was not even pushing the heli just cruising around at low rpm. I am so going back to Scorpion!!!
Nothing smaller than 700 ..... |
05-04-2014, 04:28 PM | #2 (permalink) |
Looks like the old style? I had countless hundreds of flights on mine without any issues, looks like it overheated?
If it can be done wrong, I will find a way to excel at it. |
05-04-2014, 05:03 PM | #3 (permalink) |
I just love the ****ING clowns who trash talk without PROPER RESEARCH ! !!
700N DFC 3GX OS91HZR 700E DFC IKON KDE XF700-505 CCHV160 600E PRO 3GX 450 PRO 3GX KDE BLING RAPTOR 90 3D OS91HZ 1ST HELICOPTER |
05-05-2014, 10:21 PM | #4 (permalink) |
That looks like an old V1 motor, so the question is.........how many years old is the motor and how much time is on it? Has the helicopter ever been crashed?
This can happen to any motor on the market, just because it happened to brand X does not mean it won't happen to another brand. It's very easy to bash a manufacture, but very hard to pin down the real issue. We as hobbiest need to be able to handle certain mechanical break downs. Especially products that are several years old. If you cannot handle a break down in this hobby, well enough said there. Another thing to consider is replacing major gear/products after a years worth of hard flying. Or several years of mild flying. I replace my motors and servos after one year of flying. The rest of my equipment get replaced after a couple years of flying. This keeps my helicopters in top shape for every summer to bash on, and winter for some mild flying. I also go through my whole system every Spring and Fall. Everything get's tore down and inspected or lubed to get ready for each major season of flying. Every time my helicopter goes up in the air I write it off. Whether it be from my dumb thumbs or a mechanical break down. Thanks, Chris Last edited by thenewguy; 05-06-2014 at 09:42 AM.. |
05-07-2014, 10:13 PM | #5 (permalink) |
I got this motor brand new from flying-hobby for my g770. It has less than 10 flights definitely.
05-08-2014, 07:59 PM | #6 (permalink) |
The shaft on the motor would tell another story about 10 flights.
05-09-2014, 03:14 PM | #7 (permalink) | |
maybe the OP isn't totally lying, maybe he was sold a motor and told it was brand new, but the shaft would have been my clue that it was not brand new. I have a scorpion 520 on my e7. it has about 60 flights on it thus far. I disassembled everything last week to just look and see how things were jiving with each other (first synergy heli and scorpion motor so just taking a peek). and the shaft still looks brand new (almost)there is a little line where the shaft rides in the bearing, and a mark where I tightened the setscrew down good. but absolutely nothing like the pic above.
Gasser Mike Team KDE Direct, TRM Power, Byron Fuels, MKS Servos |
05-09-2014, 04:50 PM | #8 (permalink) |
You guys are right, I had another KDE on the table and it does not look the same. The first KDE I got from flying-hobby was a V2 and the subsequent 2 units are both V1s. I did not pursue since I could not gather any information on their differences. The other unit was taken off becos the circlip came loose in flight and sparks was flying out of the motor during bench testing while this motor just seized in mid flight.
